Results 1 to 5 of 5
    Feb 2020
    Augusta, Ga
    2001 BMW X5 3.0i
    Vanos solenoid location on my 3.0i 2001 x5 intake and exhaust
    I'm having crank but no start issues
    Atlanta, GA
    2019 Silverado 2500
    Is there a question here?
    Jan 2016
    Ca
    2001 525it
    Yea need a complete description of what is going on
    Feb 2020
    Wisconsin
    2010 BMW X6 50i
    If I was a betting man, I would bet that he plans to replace the intake and exhaust vanos solenoid based on his no-start issue. If that's the cast, they are lacated right on the front of the engine (one plug and two bolts, then pull it out). You may need to remove the radiator fan housing to have easy access. It's best to replace on at a time as not to mistakenly reverse the plugs.
    Try this to help you out:
    https://www.newtis.info/?fbclid=IwAR...uffGx5e_Y_HTzg
    Atlanta, GA
    2019 Silverado 2500
    You're probably right, but I sure do wish people would be more descriptive of their problems and what they're trying to accomplish.
    I will say though, that faulty vanos solenoids won't cause an engine not to start. They just lock in a default position. Now if the gears came apart, that's a different story.
  1. F30 - Vanos Solenoid Location
    By chrisefird in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-09-2018, 09:25 AM
  2. Need help from S52 owners, VANOS solenoid wiring plug location....
    By 2391533 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-26-2013, 03:13 PM
  3. Vanos Solenoid e46 325i 2001 Steptronic
    By cla325 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-20-2012, 01:25 PM
  4. *VANOS Solenoid removal/Camshaft Sensor*
    By Farmer in forum 1992 - 1999 M3 (E36)
    Last Post: 01-02-2007, 07:06 PM
  5. Vanos Solenoid Replacement
    By TechnoV in forum 1992 - 1999 M3 (E36)
    Last Post: 11-10-2002, 04:47 PM
