I'm looking for the main body/chassis wiring harness for a 1996 328is. Preferably uncut with the fuse box.
Understand that the main body/chassis wiring harness runs from the front fog lights throughout the entire car to the rear taillights. While I have removed them whole in the past it was really not worth the time and effort as you will have to remove almost everypart of the interior etc. What's your issue?
Hey, thank you for the response. So the interior of the car is already removed. I had an electrical fire over the summer that appears to have started with the engine harness. Before I threw the new engine harness in I wanted to check over the rest of the wiring to ensure that it was all okay and discovered that a good portion of the harness running below the driver seat got melted as well.
Sending a chunk of wiring (such as the area your mentioning) is not that bad. I have a few 96 328s but they are convertibles which may have a little more wiring due to the electric top etc than the 328is but the colors etc should all match.
Text me a picture if you want and I may be able to help you out vs the entire harness which really would not be worth my time to remove.
Greg
410-967-6170
