Results 1 to 14 of 14
Thread: Fan issue
    Nov 2019
    Louisiana, USA
    1997 e38 740i
    Fan issue
    I'm restoring a '97 740i and have a question. In the dash a fan keeps running no matter if car is turned off or whatever. This kills the battery over time so its a semi-major problem. I read somewhere that there is a "module" that can malfunction and cause this. Can anyone enlighten me on how to fix this? Thanks muchly.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E38 forum from 7 general
    Feb 2020
    Nashua NH
    E38, E53, b9 a4
    Your blower motor resistor/fan assembly under the dash has failed. I recently had this problem. It requires removing the dash. Not a hard job, just very time consuming. Used part can be had for a reasonable price, just make sure it works and blows like new before reinstalling dash.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Here is a thread I made up some years back. For your model year, be sure to note the info and links on the K4 relay. It could be the resistor that sits on the blower motor but it usually just kills the power to the blower, unlike other models where it causes it to run non stop. If you have to pull the dash, you will find DIY's within the thread below. I've done this several times and, as stated, it's not a difficult DIY.
    https://www.bimmerforums.com/forum/s...eral-HVAC-info
    Nov 2019
    Louisiana, USA
    1997 e38 740i
    Fan module
    can someone tell me what "FSU module" is and what it does? I hear a small fan running in dash that I can't seem to shut off. Any ideas to fix? Would replacing fan and resistor unit do it? Its a pain 'cause I'm forced to keep a trickle charger on the car so the battery doesn't die. Thnx!
    Oct 2019
    Lake Arrowhead, Ca.
    1997 740iL BMW 03862
    the small fan seems like it would be the climate control module air sampling fan not controlled by the FSU module main blower resistor pack (final stage unit module), doesn't the small fan come on to sample the interior air temps to control the ventilation system of outdoor air flow into the car when it is off as well as key on position or the car is running not sure... maybe the climate control module is glitching if it has the small fan running constantly..... probably old capacitors need to get replaced if it is glitching.....
    Feb 2020
    Nashua NH
    E38, E53, b9 a4
    You made a thread about this already a few days ago and a solution was offered there I had thought. You need to replace the whole blower motor and resistor as one piece...problem solved..
    Feb 2009
    KC North, MO, USA
    1996 740iL
    The fan in the IHKA is activated when the car is 'awake'. The fan sits on a magnet and is activated by on of the bus systems. As stated, it has nothing to do with the blower motor and resistor. When you open your door or use the key fob, the General Module 'wakes up' the car. Once you turn off and leave the car, all systems shut down after 16 minutes, including the bus that would cause the IHKA fan to run. If the car is not going to sleep, you will need to find out why. If you sit in your car for 16 minutes after shutting it off, without opening the door, the fan should stop and the P light on the gear selector should go out. If this does not happen, you need to find out why. Timm has a good write up on his site on battery drain. It could be the climate control module (IHKA) or something else on that bus.
    https://www.meeknet.co.uk/E38/E38_Battery_Drain.htm
    May 2018
    Northwest Ohio
    1988 E24, 1997 E38 740iL
    Good advise from MC.... however, if the General Module is being kept awake by one of the busses it communicates with, the trouble shooting gets a lot harder.....and the General module itself can get a little “loopy” with old age and start doing some strange stuff as the electronics age... fun fun fun...
    Pete
    Nov 2019
    Louisiana, USA
    1997 e38 740i
    fan misery
    so, I'm restoring a '97 e38 740i and have an issue. There is a small fan (I'm thinking not main blower fan) that stays on constantly, even when car is shut down, fan speed at zero, etc. Hours later, still on. Of course, it kills battery. Anyone know how to fix or where fuse is located? Appreciate it.
    Dec 2019
    UK
    2000 E38 740i Sport
    This is the THIRD time you have asked this question - did you bother to read the answers you were provided with by other very experienced owners?
    Jul 2019
    All over
    E38, E39, 2020 GRACHE
    Quote Originally Posted by SwallownAmazon View Post
    +1
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Threads merged.
    Jul 2019
    All over
    Quote Originally Posted by chemmech View Post
    Oh my bad then I was immediately thinking blower motor / resistor under the dash but read it again and yeah then it sounds like the little fan in the IHKA climate control unit.
  1. Alright.... heater fan issues.... help!
    By Joelude in forum 1992 - 1999 M3 (E36)
    Last Post: 03-29-2006, 04:28 PM
  2. Heater blower fan issue (not resistor)
    By erikras in forum 1983 - 1991 (E30)
    Last Post: 03-26-2006, 03:09 AM
  3. Help..fan Issue
    By Cloxe in forum 1991 - 1999 (E36)
    Last Post: 12-22-2005, 02:14 AM
  4. hard wired aux fan issues - URGENT
    By texasbimmer in forum 1991 - 1999 (E36)
    Last Post: 03-05-2005, 05:43 PM
  5. radiator fan issues - HELP!
    By DakarDave in forum Forced Induction
    Last Post: 02-13-2003, 06:17 PM
