Results 1 to 6 of 6
Thread: Hard top and weather seals leaking after replacement.
    Feb 2020
    Romania
    x5 E70 /08, Z3 E36 /98
    Hello,
    I have recently replaced on My 98 Z3 ( Hard top) ;
    1. weather seal ( the one outside and around the windshield),
    2. Both the seals around the left and right windows
    3. Both Left and right window guide seals.
    I still have leaks in the car, any advise or instructions pls ?
    Thank you,
    Ioannis
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    Quote Originally Posted by Ioannis View Post
    Hello,
    Thank you,
    Ioannis
    I was able to achieve solid results by adjusting the hardtop and door windows, and then tweak the a pillar seal or maybe the front part of the hardtop window seals a bit if I recall correctly
    Jan 2016
    Ca
    2001 525it
    Depending on the leak a little silicone past may help
    Oct 2013
    Rock Hill, SC
    2000 BMW M Roadster
    Download the BMW Hardtop fitting PDF (google), and use that to precisely align your hardtop. I did this down to the millimeter and it took some time but made the hardtop much quieter.
    Sep 2010
    Kensington, MD
    '00 s52, '02 m54
    If the leak isn’t from the windows seals and is leaking onto the soft top, then check to see if the rear window seal has failed. The black rubber around the outside of the rear window is only trim, the window is actually sealed in with a butyl gasket.
    Cooper
    '00 Alpine III M Roadster (2017-Present)
    '02 Topaz 3.0 (2009-2020)
    '97 Montreal 1.9 (2005-2009)
    St Clair Shores Michigan
    2001 BMW Z3
    Where is it leaking? I know on mine, if the little rubber flap (see pictures) is tucked under the hardtop, Water will drip on the seat. They tend to tuck under when I put the top on and need to be pulled out.
  1. Replies: 19
    Last Post: 01-15-2020, 07:11 AM
  2. Vacuum leak after replacing Vanos Seals
    By LarryZooms in forum 1999 - 2006 (E46)
    Last Post: 06-05-2019, 07:42 AM
  3. Replies: 0
    Last Post: 03-15-2018, 02:00 PM
  4. Replies: 1
    Last Post: 07-31-2015, 12:30 AM
  5. Replies: 5
    Last Post: 05-28-2007, 09:16 PM
