Results 1 to 4 of 4
Thread: Oil leak near vanos area
    Feb 2020
    ga
    Hi,
    I seem to have a oil leak near the vanos/timing chain area. Is there a gasket that needs to be changed or something else?
    Haven't narrowed it down exactly where it's coming from, but it's around there.
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    There's several possible sources. Valve cover gasket, vanos assembly to cylinder head gasket, vanos supply banjo line or fitting etc...
    SW Florida
    99-01 M Cpe & Rdts, X5M
    If it's on the RH side, try tightening up the chain tensioner cap (32mm / 1-1/4" wrench or socket required). They tend to loosen up enough to weep oil.
    Dec 2013
    USA
    1999 BMW MZ3 Roadster
    Anyone have a picture of that cap? I'd like to check mine? Is there a torque measurement to tighten it to?
  1. Oil leak near Vanos solenoid
    By SHOoff11 in forum 1999 - 2006 (E46)
    Last Post: 01-22-2017, 01:17 PM
  2. S54 Oil Leak near front of Engine, Vanos Area
    By Cloudbase in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-16-2013, 02:26 PM
  3. m50 oil leak (non vanos motor)
    By hallfleming in forum 1991 - 1999 (E36)
    Last Post: 05-01-2005, 12:31 AM
  4. Oil leak near filter housing
    By Arbeitstier in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-04-2003, 06:12 PM
  5. Need Help with Oil Leak around VANOS area
    By DallasM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2003, 05:15 PM
