I pulled the old aftermarket radio today, pulled the wiring harness, cleaned off the wires of the electrical tape good that they were wrapped with, cut old harness to radio off, install new harness using clean butt connectors, removed the old radio's metal bracket that inserts into the dash, installed new bracket, pulled the old remote microphone (it was in a bad place and broken) which entailed taking apart a portion of the drivers side lower dash panel, was routing the wires for the new remote microphone up the A-Pillar (had removed the trim piece) and was buttoning everything up with more than a hint of satisfaction.
I couldn't wait to turn the radio on and enjoy the new setup. It was at this moment that I realized that the A-Pillar trim wasn't sitting just right. As I grasped it and lightly pulled, I realized that one of the two metal trim clips was broken in half and the other was terribly bent. As I tried to unbend the unbroken one, it too broke in half. So now I can't reinstall the A-Pillar trim piece.
I have searched on realOEM.com and cannot find a part number for these two pieces. Does anyone have an idea what the part number is or where to find them?
The trim piece and the clips are shown at:
https://www.realoem.com/bmw/enUS/sho...diagId=51_2347
A Pelican DIY shows them at:
Here's one of the clips at ECST:
https://www.ecstuning.com/b-genuine-...p/51438398207/
BMW MOA 696, BMW CCA 1405
You just need to order more stuff to get over the “free shipping” threshold
