Results 1 to 3 of 3
Thread: checking tranny fluid, taking off pan.
    Jan 2020
    woodburn,or
    2001 740il
    2001 740il 140k
    transmission was acting up not wanting to shift after it got warm, it did 100 mph real quick getting on freeway and then when traffic slows not so much, jumpy.. so its up on jack stands dropped pan oil was black and not much metal on magnets. whats the best way
    to upload photos on here?
    stripped 4 bolts why their that tight i have no idea, got all out except one.
    been looking online and to the hardware store to get bolts.
    who makes the best bolt kits for these and whats the torque rating to put them back in?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    use the parts catalog and your VIN to find the part numbers for the bolts https://www.realoem.com/bmw/select.do
    fastest is the closest dealer or one of the online shops, often the bolts are part of a transmission filter kit as shown here https://www.fcpeuro.com/BMW-parts/74...=5&b=5&d=10&v=
    tightening torques are in here https://www.newtis.info/
    Filling procedure https://www.europeantransmissions.co...ansService.pdf
    Feb 2020
    Nashua NH
    E38, E53, b9 a4
    If there’s no metal it should be fine regardless of how it looks. Put a new OEM filter and new fluid in with a bottle of Lucas transmission fix and a tube or dr. Tranny shudder fix and it should shift like new again. If not, then you probably have a very worn transmission. Not uncommon at all to fail by 140k on what sounds like original fluid. Either that, or your trans temp cooler regulator thing is shot.
  1. Checking Tranny Fluid on 1980 E23 733i automatic
    By goinstrong in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-18-2009, 10:40 PM
  2. Checking Tranny Fluid in E32 750i
    By V12Beamer in forum 1988 - 1994 (E32)
    Last Post: 11-08-2008, 05:07 PM
  3. Checking Tranny Fluid (1994 318i)
    By Envious in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-10-2008, 11:29 AM
  4. E-39 - Checking Tranny Fluid? and Mirror Question.
    By 5284me in forum 1988 - 1996 (E34)
    Last Post: 02-25-2004, 09:59 PM
  5. whats the best way to check tranny fluid?
    By $Rich$ in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-22-2002, 08:14 AM
