Results 1 to 11 of 11
Thread: 850I Windows will not operate,Trunk light and interior lights won't come on
    Feb 2020
    Wake Forest NC
    1991 BMW 850I
    Hello Guys, I sure hope someone can help me. My 850I has some issues, All the windows are inoperable they want go up or down. The trunk lights will not come on and the inside interior lights will not come on. Since there is so much going on there must be a common cause because it all started at the same time. I have brand new batteries put in the car. Any help is appreciated
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    General Module
    Likely you General Module Capacitors have failed. Scott here repairs them quickly for $50 ish
    Canonical thread
    https://www.bimmerforums.com/forum/s...-Bench-Testing
    Feb 2020
    Wake Forest NC
    1991 BMW 850I
    You going to have to help me with that...Where is this module located so I can remove it?
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Module
    On a LHD Car, put the back of you head on the brake pedal and look up and to the right. Its right in front of the knee bolster. Mine has a panel they you have to take out along with the heating ductwork. Two easy nuts and one really difficult if it has not come out before. I never replaced the hard one. The whole rack drops down and will hang on the wires.
    Its the Middle Module if I remember correctly
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    Before you go pulling out modules; check all relays first!
    Feb 2020
    Wake Forest NC
    1991 BMW 850I
    Thanks rjjablo and radlaw for the information. I will try the relays first since it is simplier
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    My BMW Repair YouTube Channel
    Feb 2020
    Wake Forest NC
    1991 BMW 850I
    Thanks Timm, I think all the Relays in question are the ones in the trunk that are for the windows ,door locks,interior lights and trunk lights
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, the Consumer Cut-Off relays would be top of the list, and the two green ones can be swapped over.
    Feb 2020
    Wake Forest NC
    1991 BMW 850I
    Quote Originally Posted by Timm View Post
    Timm I purchased new ones because it is a 91 and I believe these are the originals still in it but it did not fix my problem. So I am guessing that it is probably the GM
    Feb 2020
    Wake Forest NC
    1991 BMW 850I
    Everyone, my GM did have a cap that was blown. It was the biggest one in it So I hope this is the one that was causing all my problems. Now to send it to Scott to get me rightIMG_0654.jpg
  1. 6/1995 M3 Window will not drop 10 mm and interior rear lighting failed
    By davesm31995 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-23-2019, 09:52 AM
  2. 1998 m3 driver side window will not operate
    By erkj79 in forum 1991 - 1999 (E36)
    Last Post: 07-02-2018, 05:10 PM
  3. 2000 528i Passenger windows/locks not operational
    By BigIke in forum 1996 - 2003 (E39)
    Last Post: 03-27-2015, 10:38 AM
  4. Hazzard lights and interior lights on, doors unlock
    By FredRC in forum 1996 - 2003 (E39)
    Last Post: 11-06-2012, 11:52 PM
  5. FS: E36 Light Grey Interior Light Parts
    By KLEENE36 in forum Exterior Lighting & Body Parts
    Last Post: 05-28-2007, 03:58 PM
