Hello Guys, I sure hope someone can help me. My 850I has some issues, All the windows are inoperable they want go up or down. The trunk lights will not come on and the inside interior lights will not come on. Since there is so much going on there must be a common cause because it all started at the same time. I have brand new batteries put in the car. Any help is appreciated
Likely you General Module Capacitors have failed. Scott here repairs them quickly for $50 ish
Canonical thread
https://www.bimmerforums.com/forum/s...-Bench-Testing
You going to have to help me with that...Where is this module located so I can remove it?
On a LHD Car, put the back of you head on the brake pedal and look up and to the right. Its right in front of the knee bolster. Mine has a panel they you have to take out along with the heating ductwork. Two easy nuts and one really difficult if it has not come out before. I never replaced the hard one. The whole rack drops down and will hang on the wires.
Its the Middle Module if I remember correctly
Before you go pulling out modules; check all relays first!
Thanks rjjablo and radlaw for the information. I will try the relays first since it is simplier
Here's the Fuse Finder:
https://www.meeknet.co.uk/e31/Timms_...use_Finder.htm
...and the Relay Finder:
http://www.meeknet.co.uk/e31/Timms_B...lay_Finder.htm
My BMW Repair YouTube Channel
Thanks Timm, I think all the Relays in question are the ones in the trunk that are for the windows ,door locks,interior lights and trunk lights
Yes, the Consumer Cut-Off relays would be top of the list, and the two green ones can be swapped over.
Everyone, my GM did have a cap that was blown. It was the biggest one in it So I hope this is the one that was causing all my problems. Now to send it to Scott to get me rightIMG_0654.jpg
