Just curious which slide hammer, other members recommend, I've been poking around online, trying to decide which one I want to spend money on, im rounding up tools to tackle my Z3 rear wheel bearings, which look like the originals. Most of the slide hammers pretty much look the same, ranging from $50 on up.
Harbor freight has a nice one foe the money.. I got mine from a pawn shop for 15 bus. Be sure to check pawn shops
I rented at auto zone
For the rear wheel brngs, you NEED a pretty heavy one, I'd say as big as you can get!
Note the size/mass of the hammer
Likewise, the span of its travel; and even at that, it takes several substantial blows to pull the hub out of the bearing.
Same setup is used to pull the front hubs/bearings too.
Those bearings can be a bear sometimes to remove
Got mine on Amazon for about $60. Hammer about 5lbs. Worked fine.
You DO NOT need slide hammer for front bearings. After nutt is off the hub should come off by hand. If not, a simple 2 arm puller will pop it right off.
An investment, yes, but in turn I made money with them.
You can compromise working on your own stuff, but when you work on other people's cars, there's only one (1) chance to do it right.
Knowing how quickly factory tools can go out of production (My Healey & previous MGBs are examples) I elected to buy ALL the S52/S54 engine tools (+ ther VANOS tool for the 2.8 TU) plus routine maintenance tools (suspension & whl brngs, etc.) while I could. They did remain available for longer than I expected, but the prices very quickly outpaced the national average; put this way, they would've made XLNT investments, as they could sell in a few years for DOUBLE and still cost less than their current market value!
For the record, there is also very little margin on (BMW) selling tools, and even if you're tax exempt (parts for resale) you still pay tax on the tools. Not a problem for me, as going forward I'll only be working on my own cars__but rest assured, I'll still continue producing the reinforcement kits.
Interesting, I might have to hit you up on the reinforcement kit, although while I had my subframe dropped, I checked all my welds, all seemed to be ok, I plan to run my M52TU, until I round up parts needed for an LS swap, one of your kits would be a nice addition to the future endeavor.
https://www.autozone.com/loan-a-tool...r-slide-hammer is what I used on my rear wheel bearing.
No disrespect to anyone but, in today's age you can alwaysbuy the biggest best thing out there, but right next to it is an affordable durable option.
