Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 95
Thread: 1995 M3 S50 engine rebuild
  1. #51
    Dec 2011
    Canada
    E36
    "JitteryJoe" If you don't mind me asking what was the power numbers looking like and what did the rev'ing change to? Did you do the work yourself?
  2. #52
    NY
    skateboard
    Quote Originally Posted by BMW Rated View Post
    This
    ― George Orwell
  3. #53
    Jan 2019
    MI
    1997 BMW M3 Sedan
    Color me interested...
  4. #54
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Sorry, I don't have dyno numbers yet. The entire set up has just recently been sorted out. The engine was balanced during rebuild and freely revs well into redline. I'm running JE 11:1 pistons and Epic Motorsports Sport cams with race spring, stainless valves, M50 intake manifold, 24lb injectors, 3 1/2" MAF, ASC throttle delete, SAP delete, and wide diameter long tube stainless headers, mid pipe, etc. The tune is by Epic. The seat comparison says the car has lots more power, especially at the upper range. The short block and head was done by a local machine shop/engine builder that specializes in BMWs. They did the crank, rod & piston assembly and installation. I did the rest of the engine assembly. The entire suspension was rebuilt (by me). I'm running a JB Racing single mass steel flywheel. The machine shop
    balanced the clutch assembly.
    Right now the car is in storage while I move (which has turned out to be an enormous pain in the butt).
    The last little bit to do is to swap the current TB with a Dinan unit which I'll have to have someone else do because my garage has no room for the car right now (full of moving stuff).
    I will post dyno numbers when I have them.
  5. #55
    NY
    skateboard
    Quote Originally Posted by JitteryJoe View Post
    Moving sucks. Did you happen to have to need to time the cams differently then stock?
    ― George Orwell
  6. #56
    Dec 2011
    Canada
    E36
    Ahh ok. That's a lot of work and sounds good. Look forward to seeing the numbers when you have it available. I have yet to find a shop that does rebuilds for a decent price on my side of the world.
    As for moving yeah it's a pain and probably one of things I don't enjoy on any level! Lol.
  7. #57
    KC
    1995 M3 & 1998 M3 coupes
    Turbo is a big commitment and you should make that decision now. I did a complete engine rebuild (everything was done) recently. I opt'ed for NA with higher compression pistons and higher lift cams plus a bunch of other stuff. If M3FORUM was operational you could take a look at the journal. The result was plenty for me. A high rev'ing engine with good power. Turbo will definitely get you a lot of grunt. You can double (or more) the HP output. Really depends on what you want. I'm not a fan of FI on these motors but a lot of people swear by it. Also, a super charger is probably less invasive and was offered as an add-on by Dinan. You won't get the same power but likely less money and an easier fit. You have options. Good luck!
    If M3forum does ever come back up I will definitely take a look at your journal. I like the idea of a high revving NA motor.
  8. #58
    Nov 2010
    Whidbey Island, WA
    Quote Originally Posted by GG///M3 View Post
    No change and no vanos limiter needed. Runs on pump gas. With race cams it would probably be a different story. Engine is pretty thumpy at idle with the sport cams. Race cams would be too much for the street.
  9. #59
    NY
    skateboard
    I had those same cams, and the motor wouldn’t run right with them. Epic was no help in figuring them out. Another forum member who I purchased them from said they did need to be adjusted slightly differently then stock.
    I ended up removing them. It would be interesting to see how they perform.
    ― George Orwell
  10. #60
    Nov 2010
    Whidbey Island, WA
    What did you use for replacement cams? Schrick?
  11. #61
    NY
    skateboard
    Went back to stock.
    ― George Orwell
  12. #62
    KC
    Block ready to be taken to the machine shop. Don't mind the excessive amount of Topo Chico in the pic.
    Biggest issue now is trying to find a place for all the parts in the garage. Already limited on space. Every time I need to work on the car I have to temporarily move things out in the driveway.
  13. #63
    KC
    Forgot about a picture I took of some old cylinder heads outside of a cylinder head machine shop. Mother of god those cylinder heads are enormous! You can see an old small block cylinder head in the pic for size reference. I am assuming they are some sort of big rig diesel cylinder heads.
  14. #64
    Nov 2010
    Whidbey Island, WA
    Decide what you are doing? You certainly got a lot of input.
  15. #65
    KC
    Definitely a lot of really good information given so far. Still going over numbers but plan to make a decision soon.
  16. #66
    KC
    In a bit of a holding pattern at the moment. Screwed up my shoulder recently and the MRI showed that the supraspinatus tendon of the rotator cuff is over 50% torn off the bone. Good times! Going to need surgery to repair it so I will be out of commission for a while after the surgery, at least with regards to doing any work on the motor. Had multiple shoulder surgeries in the past so nothing new to me.
    In the mean time before I schedule a surgery date I need to get the engine and cylinder head dropped off to get the machine work done. And I am putting together a list of every single part, nut, bolt, gasket etc that I need so I can get the process of rebuilding this engine moving forward. I will post my list soon and see if there is anything I am missing or forgot about.
  17. #67
    KC
    Ended up emailing back and forth with 515 Motorsports about my engine build and parts to purchase. It's great finding a shop where the techs are really into E36 BMWs! Planning on speaking with them in more detail over the phone and possibly in person to get their opinions on what components can be reused and what they recommend replacing base on their experience. Hopefully with that knowledge I can gain some clarity on this build.
  18. #68
    Mar 2019
    Silver Spring, Maryland
    1990 325i
    If this helps with your decision I recently rebuilt my s50 with forged rods/pistons for turbo build and did cutring HG arp head studs and 3 angle valve job on my head with new exhaust valve guides.
    I spent 900$ in machine work (hot tank,deck, hone, valve job) and $2100 in new seals,bolts,bearings, and rotating assembly. I put everything back together myself and the motor runs great NA even at 9:1 comp while i'm still braking in the new rings (turbo going on this summer) all together it was worth the money for a good 700+ motor set up.
  19. #69
    KC
    Quote Originally Posted by E30s50dude View Post
    Thank you for the feedback. Did you reuse the valves, valve guides, springs and lifters? Or better yet what did you replace on the cylinder head?
    Good to know it still runs great even at that low compression. Not that you are getting on it during the break in.
  20. #70
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Do the moto tune break in and you do get on it.
    With a tune, low CR works fine. Probably down 4% in power.
  21. #71
    Mar 2019
    1990 325i
    [QUOTE=E85STI;30432600]Thank you for the feedback. Did you reuse the valves, valve guides, springs and lifters? Or better yet what did you replace on the cylinder head?
    Yes I reused everything from the head and the valve train, since everything was within spec I only had to replace the exhaust valve guides/ which were a few bucks and I got a 3 angle valve job with new valve seals to ensure the head was sealing perfectly. Motor had normal carbon build up and did not have any issues before I pulled the block apart. Engine had 118k before I rebuilt it, and I put about 20k on it over 3 years from when I did the swap out of high school before I decided to turbo it now.
    I do get on the car to let the rings seat, I let the car idle at 2K rpm for 25 min on first start up and drive 25 miles on highway doing full throttle pulls to redline (7k) from 3-5th gear and let the engine rpms come down by themselves on deceleration with no rev matching. I did the same thing when city driving for another 25 miles before changing the oil running conventional non synthetic 5w-30 for the first 1k miles before I switched to 5w-30 synthetic and drive normal again. No smoking issues or leaks to date now it ready for the turbo in a few weeks.
    This is the standard break in procedure we do at Acura for our engine rebuilds before we give them back to the customers. I just do multiple oil changes on my personal car in 250 mile intervals during engine break in, to ensure everything is staying free of any foreign debris. Which to some can be excessive but I like to do it as preventive maintenance before I go back to normal driving routine and my 3k oil change intervals. My car is running on flex fuel but full e85 at the moment NA with a custom 22rpd OBD2 tune NA.
  22. #72
    Oct 2007
    Louisville, KY
    1995 M3
  23. #73
    KC
    Figured I would give an update to the thread. Life and family issues got in the way and I have unfortunately made zero progress from my last post. Hoping to get things moving sometime in the near future.
  24. #74
    Oct 2007
    Louisville, KY
    1995 M3
    Quote Originally Posted by E85STI View Post
    That’s understandable, please keep us in the loop when you do. Did you narrow down the brands/specs of parts you were going to use. For example, I want Supertech springs and retainers... but 67lbs or 80lbs seat pressure? Also, are WPC treated bearings worth it? What is the cost difference between reconditioning the stock rods vs buying brand new K1 or Molnar rods? I think new rods are $600 a set with ARP bolts. Wonder what reconditioned stock rods with ARP bolts cost.
  25. #75
    KC
    So life has thrown me a few curveballs and I think I need to change my plans on this entire rebuild process. I have been throwing around the idea of just trying to sell the the entire car and components as is and just getting another car. One of the major issues happening is am going to need a couple more surgeries over then next 6 months which I am not looking forward to. I have owned the M3 for almost 10 years now and I have loved it, but I think it is time to move on. The car has rust that I don't want to fix and other things that older E36 models all need attended to.
    I am honestly just burned out with it all right now. Maybe I can post it locally on Craigslist and hope to get 3k for it all, but that may be a pipe dream I don't know. Not sure, am I crazy not fixing it up and getting it in working order and trying to sell it as is? I'm curious what your thoughts are on this. It's always good to bounce thoughts and ideas off other E36 enthusiasts.
  1. 1995 M3 S50 Engine Rebuild
    By Campagnaj in forum 1992 - 1999 M3 (E36)
    Last Post: 09-07-2013, 11:20 AM
  2. For Sale in North NJ: 1995 M3 S50 Engine $1250
    By monger in forum Engines, Performance Parts & Software
    Last Post: 05-22-2009, 06:19 PM
  3. 1995 M3 S50 Engine for sale
    By Gombay in forum Engines, Performance Parts & Software
    Last Post: 03-23-2009, 03:28 PM
  4. FS: 1995 M3 S50 engine (TX)
    By girolamous in forum Engines, Performance Parts & Software
    Last Post: 01-27-2008, 11:10 AM
  5. BMW e30 318 with 1995 M3 S50 Engine
    By steve k. in forum BMW Cars For Sale / Wanted
    Last Post: 07-16-2006, 01:47 PM
