1st time poster. battery was dead on my 1999 m3, so i charged it through the engine compatment, car starts, but trunk won't unlock, with key, fob, or anything else i try. Please advise, couldn't find a solution on this forum
Do your back seats fold down?
https://www.youtube.com/watch?v=pdpQdGtuECo
You crawl through your car into the trunk and pull the liner away from in front of the latch. It's sort of a pita, more so to put everything back. But if that's your only way in I guess you gotta do it
Feel free to ask about my car:
TRM Coilovers 560f/784r | Epic Motorsports Tune | Apex Arc-8 17x9.5 et35 | Wilwood SL-4 BBK
M50 Manifold | ASC Delete | Dinan BBTB | Fan Delete | Power Pulleys | Dinan CAI | S54 Oil Cooler
Z3 Rack | Crossbrace | 3.38 LSD | Dinan Strut Tower Brace | AKG Chassis Mount Shifter
SS Long Tubes | SS Race Exhaust | LTW Replica Wing | MM Underpanel | CF Sunroof Delete
OE GT Front Splitter | Rear Rollbar | Rear Seat Delete | BW Fuel Starvation | Turtle Labs Door Panels
And Really Old Paint
Check out my YouTube channel for more DIY's and videos about my E36 M3
Is the lock all the way out? Sometimes it sticks partially in and won’t engage or disengage.
Once you get it open, check the sheet metal around the lock for cracking. It happens. Braymond141 sells a nice reinforcement plate (and new alarm/opener key fobs that work).
I recently had this problem. For mine it was a little white plastic clip that receives the control rod (for lack of a better term). The rod snaps into this clip and mine had gotten so tired that the rod would pop out. Grabbed a couple from the junkyard and it has been fine. Once you pull the liner it will be obvious if this your issue.
