After putting together my E30 I have a container parts box of leftover bits. I mostly know what they are and where they go except for this....
Its like a large and thick washer of some kind.
25mm wide. The hole is 13mm, and the thickness is 4mm
The inside hole is slightly beveled/stepped, but only on one side.
Do any of you know what it is?
don't drive the car another inch man!
omg. get the bentley out.
Sent from Hell using Tapatalk
what did you have apart? the engine?
No e30s again.
That ain't good. That is a head bolt washer.
I got a box of the old bits back after the engine rebuild. If they had used a new set of head bolt washers, why would there have only been 1 washer in there? It should have been 14. mmm
Actually its fine. This pic I took after the engine was built shows all bolts have washers. Weird how i ended up with 1 only though...
I was going to say its a head bolt washer but I wanted to make sure that was what you had worked on.
I keep those when I do head gaskets because they are thicker then normal washers and can be used on non-e30 items when I need stronger washers
No e30s again.
