Results 1 to 6 of 6
Thread: What is this thing attached to the engine?
    Feb 2020
    Marietta, GA
    2002 BMW Z3
    What is this thing attached to the engine? (SOLVED: It was the VANOS)
    2002 Z3 Roadster 2.5L
    I noticed a tiny puddle under my car this morning of red fluid on the floor.
    Took a few photos tonight and traced the leak to this hose in the photo below.
    The first photo shows end 1 of the hose attached somewhere deep near the engine. It is under the oil filter.
    The second and third photo show end 2 and what it is connected to.
    Anyone know what this thing is? Replacing that seems like it will be fun with how tight the space is :whistle:
    Kent, Ohio
    1998 M Roadster
    That's your VANOS (variable valve timing) solenoid. It uses engine oil pressure which is what runs through the lines. If your oil drip is red, then that's not the source of your leak. More likely it is power steering fluid that is dripping.
    Feb 2020
    Marietta, GA
    2002 BMW Z3
    Quote Originally Posted by Mr Bingley View Post
    That makes more sense! Now to locate this leak.
    Oct 2003
    Seattle
    99 M3
    ...and more than likely your power steering uses ATF.
    SIN CITY
    MANY TO LIST
    If your leak is on the driver's side from those hoses, most likely is the steering fluid, the reservoir and hoses get old and need to be replaced. Done it last weekend, no more leaks.
    Road racing addict.
    Juker008 don't send pm soliciting or advertising, against forum rules!!
    May 2012
    Springfield,IL
    2000 Z3
    I had a PS fluid leak. I isolated it it to loose hose clamp (the one that plugs into the bottom of the reservoir). Apparently the hoses shrink with age causing the clamp to not be tight enough. I may have replaced the sealing ring for the PS reservoir cap which is another common source of leaks.
  1. Replies: 4
    Last Post: 05-24-2014, 09:15 PM
  2. odd things end up in engine bays
    By var1ant in forum 1983 - 1991 (E30)
    Last Post: 08-09-2006, 08:00 PM
  3. Maintenance advice while things are off the engine
    By turnerNCM3 in forum Forced Induction
    Last Post: 04-01-2006, 05:57 PM
  4. Two things needed: panel behind engine block and seat belt cover
    By ///Mr. Three in forum BMW Parts Wanted
    Last Post: 01-14-2006, 12:03 AM
  5. Is there such a thing as a "bass engine"
    By Blazin95Red325i in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-16-2004, 11:12 AM
