Results 1 to 8 of 8
Thread: Cooling System Bleed issue after replacing Water Pump and Thermostat
    Feb 2020
    Tahlequah, OK
    2009 BMW 335i
    Question Cooling System Bleed issue after replacing Water Pump and Thermostat
    When I go through the process of "Bleeding" the Cooling System, COOLANT SHOOTS FROM THE BLEEDER SCREW!!!
    1. Undo Cap from Coolant Expansion Tank
    2. Loosen Bleeder Screw 3-4 revolutions (Enough for air to flow out)
    3. Turn on Ignition (*NOT ENGINE)
    4. Turn Climate Control to MAXIMUM Heat and LOWEST Fan speed(1 Bar)
    5. Fully depress Gas Pedal for 10-12 Seconds, then release to begin process
    Allow vehicle 12-15 Minutes to bleed the air out of the Cooling System from the Bleeder Screw... it was never mentioned the screw should also bleed COOLANT
    Coolant does not leak from Bleeder Screw when fully tightened.
    Improper Procedure?
    Something else needing attention?
    Alternative route?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved from BMW Rides & Events to here.
    I never use the bleed screw on vehicles with electric water pumps. Obviously, as you have figured out, the bleed screw must me fully tightened to perform the bleed procedure.
    Canada
    750 F01, 850i, LR3 HSE
    1. You do not need to loosen the bleed screw, leave it alone.
    2. Coolant will come out of the bleed hole inside the expansion tank which will be visible with the cap off.
    3. The coolant shooting from the screw, which should be left alone is normal.
    Mark.
    Jan 2016
    Ca
    2001 525it
    It bleeds it self when the pump is activated, your good to go
    Feb 2020
    Tahlequah, OK
    2009 BMW 335i
    Thank you all for your feedback. I was not aware that it is not necessary to loosen the bleeder screw when doing this. Thank you, again.
    Jan 2005
    StL, MO | LA, CA
    e36, e90
    I ws under the impression that I NEEDED my car to be hooked up to a battery charger to run this procedure. Are those who say that being overly cautious?
    Current: 95 M3 Turbo | 08 335i
    May 2017
    Ontario, Canada
    335i E93 N54
    Those instructions are from someone's memory...
    I loosened the screw as I filled, until it was ready to come out.
    Then tightened and did the procedure. (10~ mins)
    Then I topped the fluid back up.
    I used a charger for the full 10 minute runs, as 400 watts for 10 mins is a significant drain.
    Not doing so is pretty risky IMO.
  1. Same coolant leak after replacing water pump and thermostat
    By fedisrico in forum 1996 - 2003 (E39)
    Last Post: 03-01-2019, 02:28 PM
  2. Z3 won't start after replacing water pump!
    By NMartin in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-03-2013, 09:26 PM
  3. Weird issues after changing water pump
    By alphabimmer in forum 1999 - 2006 (E46)
    Last Post: 03-05-2011, 01:04 PM
  4. Odd leak after replacing water pump
    By m5hoot in forum 1996 - 2003 (E39)
    Last Post: 01-25-2011, 10:57 PM
  5. engine spinning fast after replaced water pump. car doesnt start PLEASE HELP
    By vo1tage in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-11-2009, 01:10 PM
