Results 1 to 4 of 4
Thread: 2006 X3 No Spark
    Columbus, NJ
    06 BMW X3
    2006 X3 No Spark
    2006 BMW X3 3.0. 205k miles
    Car turns over but won't start.
    Hit a deer a few weeks back. Small deer, little damage. Was able to drive the car home. Next morning when I started it I noticed leaking coolant. Coolant reservoir had a small crack and was leaking. Never overheated. Car sat for a week waiting for the part. Swapped it and now the car won't start.
    I'm getting fuel at the rail and can hear the pump. I pulled the plugs and checked for spark. Nothing there. Coils are a couple years old. Checked all fuses, they are good. Battery is less than a year old and has been on a charger.
    No OBD codes.
    Used an Autophix 7810 (BMW specific reader) and got the following:
    ECM Engine Control module:
    2800 No message (inst. cl. 2) from Instrument cluster
    2809 No message (inst. cl. 3) from Instrument cluster
    EWS Elec. Immobilize System:
    0F power on reset
    ABS/ACS/DSC Dynamic Stabilty:
    5EB1 Steering-angle sensor, supply
    D35A No message (instrument cluster 615)
    ZKE Central Body Electronic:
    07 Anti-theft alarm systems: siren, radio interior protection, tilt alarm sensor or wire STDWA short circuit to ground or open circuit
    30 K-bus or Control unit for instrument cluster basis (Gateway)
    Not sure what is going on here but obviously the instrument cluster is having trouble. Not sure if the Anti-theft system errors could be causing this either. Car ran great before this issue but never ran the codes previously so not sure if these have been there or not.
    Any insight?
    Jan 2016
    Ca
    2001 525it
    If the dash lights up but the engine won't turn over try another key
    Columbus, NJ
    06 BMW X3
    Quote Originally Posted by jclausen View Post
    Edited the first post. Car does turn over, just won't start. Plugs smelled like fuel as well when I pulled them so I know they are getting fuel.
    Cave Creek, AZ
    1993 850ci 2001 M5
    Is it possible that either the crank or cam sensor was damaged in the impact? That could potentially prevent ignition
    Regards,
    Brian
    Cave Creek, AZ
  1. BMW has updated their website for 2006 X3
    By MoyMch in forum 2003+ X3, X4 (E83, F25, F26, G02)
    Last Post: 09-18-2005, 01:09 AM
  2. Any news on the 2006 X3
    By MoyMch in forum 1999+ X5, X6 (E53, E70, E71, F15, F16)
    Last Post: 07-30-2005, 04:03 PM
  3. Getting ready to place my order for a 2006 X3
    Last Post: 07-24-2005, 03:42 AM
  4. Has anyone neard about the 2006 X3 and the new engines?
    By miron88 in forum 2003+ X3, X4 (E83, F25, F26, G02)
    Last Post: 07-23-2005, 03:44 PM
  5. Pics of the 2006 X3 3.0
    Last Post: 07-21-2005, 05:59 PM
