i deffenetly made a mistake, while installing a simple (what i thought was simple), upgrade in my 1997 740il. I used the brown,( pos. wire from the telephone connector, and the blue with stripe ground). the usb charger don't have a grounding wire and I didn't think about it but I wired the negitve wire from the charger the ground from phone connector, it started to charge my cell phone but as soon as it did I go0t a clicking sound from the dash and theabs light was slightly dimming as it was clicking I unwired the device and the clicking continued I never started the vehicle only had it in posetion1 and I also disconnected the battery hoping that it would reset any modules to no avail. I got home from work and reconnected the battery and the nav screen turned on when I turned the key to pos.1 but it soon turned off and now will not turn on I also lost the climate control read out but the backlighting is on. I have no idea what to do now or how to fix this but before my stupid idea everything worked fine
Brown wires on BMWs are typically ground.
88M3 AW 43k miles Project FS
I recharged my battery and everything is working at the moment, I bought my bmw for $500 and finding out that it is going to be well over the price of the car to sort out all the problems, I has a new problem that I found I have two chips in the glass lens and the headlamp is not working the turn signal turns on but not the headlamp. I changed out the bulbs to see if they where dead and they work just fine in the other headlamp. My question is if I put in a new or "new to the car" headlamp would I have to reprogram the headlamp to the lcm, and I think my lcm is also not working and could be the problem.
Have you checked the fuses? Next would be to check for power at the lamp connector.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Yea you may just be a the tip of the ice burg on this $500.00 car
