Hi guys,
i have problem with coding module GM5 in NCS Expert , car : BMW E46 2003.
I changed module comfort from LOW to HIGH , without problem i can read module GM5, but when i try to SG_CODIEREN empty MAN file or filled TRC file i get message:
I updated sp-daten to V66, my old module LOW i could normally write job sg_codieren...
I found some information that mayby there is VIN protection in module GM5 (?), unfortunatly i am newber in NCS Expert.
Thanks for any help or tips!
Did you also rewrite vin in your new module? Post screenshot from Inpa with information about all modules with vin number, it's F3 (UIF).
I'm almost sure that your problem is old vin number with new module.
If my answers help you to FIX your problems with car, you can always donate me using PayPal :
https://www.paypal.com/cgi-bin/websc...MNN&source=url
Thanks for quick reply!
I didn't think I needed.
Here is ident tab from INPA for ZKE5/GM5:
or from all modules:
Can i write to my VIN with program NCS Expert or WinKFP?
In WinKFP i could't find ECU family for my module ZBnumber ( i updated to SP Daten v66 ).
I have only this Ecu Families:
HI
Not exacly those screenshot I wanted but doesn't matter.
Yes you need to change vin in module.
Duzo szybciej bedzie jak zmienisz VIN w GM5 uzywajac PA Softa, potem normalnie zakodujesz do ustawien fabrycznych za pomoca pustego mana.
Upewnij sie tylko ze uzywasz profilu expert a najlepiej revtora.
I hope that guys don't have problem, but I will reply in polish.
Do samego kodowania pustym manem nie potrzebujesz prostownika, tak samo dopisanie vinu w PA Sofcie to kilka sekund.
Jednak jakbys flashowal (ale nie bedzie to wymagane) to prostownik wrecz zalecany.
Osobiscie uzywam prostownika za kazdym razem, nie wazne czy tylko koduje czy flashuje, lepiej dmuchac na zimne; szczegolnie przy autach klientow.
Jakbys mial wiecej pytan pisz na fb: https://www.facebook.com/Bimmer-Car-...2220191149484/
Pozdro
W PA sofcie dla modulu ZKE nie mam mozliwosc Write FGSTNR , jedynie ADFG , probowalem w nim wpisywac 4 ostatnie cyfry vin i poprzedzajac go dwoma zerami albo dwoma 55 jak w innych modulach ale problem dalej jest. Zczytalem eeprom ale niewiem w ktorych blokach pliku jest VIN umiejscowiony. ( eeprom daje sie zapisac spowrotem)
Przy probie wlaczenie jakis funkcji przez PA Soft : Coding Data write : Fail
Zczytywalem rownie plik .EPB ( da sie go zapisac spowrotem )
