I bought a 2006 330 I and after buying it one day the car just shut off and I thought I needed to just put coolant into the car and come to find out I had to replace the radiator and battery which at this point I have done. however the original estimate was from Pep Boys when I took my car to my regular mechanic they told me that there were several other things that need to be fixed/replaced:
-the oil can gasket
-the oil filter gasket
-transmission pan gasket
-valve cover gasket
-the lower strut bushing.
The radiator and battery (with all of the hoses needing to be replaced) cost me around $1300. I got a flat tire last and today I am replacing all 4 tires (with standard tires not run flats bTw). Before I say this next part let me start by saying I am planning to get everything on this list repaired/replaced but I asked the mechanic what was the MOST important to the safety/integrity of the car (so I don’t cause further damage)to get done first & what can I hold off on until later when I have the money for it. After looking online myself I basically got the sand answer everywhere that driving the car with the oil/transmission gaskets needing to be replaced is not dangerous so long as the oil and transmission. fluid isn’t leaking too much/fast and are at the level they need to be. Can I go ahead and just get the lower strap bushing replaced and then over the next few weeks/months tackle the other things 1by1. Getting all this work done is going to already put me over what I paid for this car but I love the car is beautiful and it’ll be worth it in the long run if after I get all of it done I have relatively speaking, a new car.
FIRST avoid Pep Boys as if venereal disease, seriously, these guys are Earl Scheib with a wrench. Fine for fixing that old Corolla but not for this car.
Find someone familiar with BMWs. Ask your local BMW club for someone well regarded in your area.
Nothing on your list is out of the ordinary. The oil pan gasket is labor intensive so an expensive job.
Not sure what "lower strut bushing" is but BMWs do eat suspension bushings with amazing regularity.
Try www.bimrs.org to find a reputable indie shop that specializes in bimmers in your area.
Pep boys, you can do much better than tha, find a good independent shop who knows what there doing and you own a high maintance car too
As others said, do not go to Pep Boys! DO Not! Any local BMW mechanic via Google Search would be better off than PB. Start spending some here and you'll get valuable guidance from folks on this board. There was time when I did not know how to change tires on my father's vehicle but slowly over time, with guidance, you'll be able to make somewhat wise decision.
If you are in Central NJ area, I wouldn't mind helping (no cost) from stuff that I learned from here.
All the best!
