I am wanting to install a mini bluetooth Amp in the OEM location. Is there any adapter plugs that connect to the stock Amp plug, so if I ever want to use the stock Amp again I could?
Hi,
There's not enough information to help you here. Which amplifier exactly are you wanting to install? As for connection, assuming you'll be doing BT audio streaming to it, it will need power/ground and the remote switch on wire connected to a switched 12V supply and you'd be good to go. Check to see if the OEM amplifier connector plug has those connections on the Pins and see if you can get a used connector and splice in the wiring you need to it and then in turn, plug that into the car's harness
Cheers, Dennis!
