Hello,
I was wondering whether the tuner will play without the Business CD unit attached? I never use the CD and would like to put something else in that dashboard slot if possible.
Thanks,
rmarinius
Hi,
Check in the E39 section as well, but I don't think it'll work if you remove the CD portion. Might be wrong ! give it a try and test ?
Cheers, Dennis!
I'm fairly certain that the MID does not do any tuning, all of the radio functionality should come from the CD player or the Tape Deck, the MDI is just the interface, although I'm not 100% on that. I know qsilver7 probably would know.
KEVIN
BMW CCA # 416146
Current 2001 525i-5 / 234,000 Miles
///M Weighted Shift knob.
CD43 with AUX retrofit + Bluebus
Auto Dimming Mirror upgrade
H&R Sport / Koni STR.T
OEM Xenon HID Retrofit
The Ex- 2000 540i-6 / 82,xxx miles to 186,xxx miles
CDV Free, 545i Shifter and ///M Weighted Shift knob.
Member of DSC Module Failure Club $$
