So our E46 is just finished. 2JZ 6466 @ 20 PSI and it already broke the axles. Plan is to raise the boost up to 30 PSI so this got me thinking i'm better of with swapping a 8.8 rear end already and stop investing in the M3 rear end with DSS axles.
I came across this:
https://www.seemslegitgarage.com/pro...frame-axle-kit
Does anyone have experience with these guys?
Thanks in advance
Looks good if $3650 is no big deal. That does not include the diff but building a Ford diff is not as expensive. Figure on at least $4k by the time you are done.
In my E36M3 with fully built turbo S52, I run DSS axles, a slightly modified stock subframe and an E32 750il 210mm 3.15 LSD. I have spent $1,200 (but shopped patiently and carefully). No issues on the street or drag strip with 600-700 rwhp and I have no doubt it would hold 800 rwhp or more. I know of others drag racing with the same parts and that much power.
But your $4000 option looks good.
