Hey guyz!
All of my steering buttons stopped working.(The horn stopped working too,lights on the steering buttons gone too), and i got an airbag restraint system error.
Theres my error codes from SGM airbag module:
93D9 Abschalten von Modul 3 (SZL E65, TEFAT E6X) (Switch off by Module 3, SZL E65)
9446 Pre-Drive-Check n.i.0. wegen Modul 3 (SZL E65, TEFAT E6X) (Pre-drive check not ok. because of module 3)
And my SZL module stores these errors:
94EA Kommunikation zwischen Lenkrad und Lenksaeule fehlerhaft (Communication between steering wheel and steering column fault)
951A Spannungsueberwachung LRE unterer Grenzwert unterschritten (Voltage monitoring LRE below the lower limit)
9518 Spannungsueberwachung ASE unterer Grenzwert unterschritten (Voltage monitoring ASE below the lower limit)
94E3 Klemme U_Isis fehlt (Terminal U_Isis is missing)
This can be a broken steering column cable or clockspring?
I think not my SGM module cause the error(or I might be wrong)
Thank you for help
Same happened to me... Long before the steering wheel buttons and restraint faults my heated steering wheel was out too.
This what I found:
Thank god I had new clock spring already so I just replaced it and cleared the codes and everything has been working ever since. I bought a cheap one from china for testing purposes and it's over half a year and still good. I think it cost around 25-27USD.
Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS, E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
