Results 1 to 2 of 2
Thread: M50 Camshaft Position Sensor Pinout information
    Feb 2020
    Australia
    2000 BMW E46 328Ci
    Hi all,
    I have been searching high and low for this information but can't seem to find it. I am doing a Haltech Elite 2500 installation in my 3 series race car. The wiring harness was completely stripped and a new one made. To make the Haltech work, I was told I needed to ditch the E46 Cam Position Sensors and swap them for M50 cam position sensors, otherwise it can damage the ECU (or at least not give a reading).
    I bought some aftermarket M50 Cam Position Sensors and now need to wire them in to the car but I cannot find a pinout diagram for them, and the colours on these sensors do not match the factory so I can't use a factory wiring diagram. Does anyone have a pinout diagram for the M50 Cam Position sensor?
    Dec 2004
    Charlotte, NC
    2008 BMW M5 SMGII
    I just got done running my M60 with a Haltech 550. The M60 uses a 2-wire reluctor camshaft sensor, so I am assuming you have a 3-wire hall effect sensor (I have heard that some reluctor sensors can have three wires for gounding). If it is a hall effect sensor, you need to just do some testing - apply dc voltage to one prong, ground another prong, and then measure the voltage of the third prong while moving the sensor across some steel as it should fluctuate. I don't think getting the wiring wrong will damage it. The issue I had with my M60 is I needed to change the crank sensor to an M50, and then it started to catch.
  1. Z3 camshaft position sensor Important information
    By jacob5525 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-29-2012, 03:17 PM
  2. '01 Sport - Camshaft Position Sensor went bad
    By red740is in forum 1995 - 2001 (E38)
    Last Post: 10-18-2005, 04:59 PM
  3. camshaft position sensor
    By johnnym3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-20-2004, 05:48 PM
  4. fs:camshaft position sensor(new)
    By DarkM3 in forum BMW Parts For Sale
    Last Post: 01-12-2004, 03:35 PM
  5. Camshaft Position Sensor
    By bjchacha in forum 1991 - 1999 (E36)
    Last Post: 03-28-2003, 01:06 AM
