Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 76
Thread: E36 S50/M52/S52 Turbo Camshaft Options
  1. #51
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    I’ll take a set as well if you are making them to Chikinhed’s specs.
    I'm going to be very interested in seeing these work on your car Phil. Maybe I should throw mine in at stock timing and we can compare idle and driveability and stuff like that.
    Sent from my SM-A505U using Tapatalk
    PTE6262 .63 A/R, Stock S52, Cutring/Copper Spacer/Arp Studs Combo, Water Methanol Injected
    10.9@131mph. #AngerMotorsports
  2. #52
    Vancouver, B.C., Canada
    '97 M3
    The 264/256 set with the blocks idled at 16-17 “Hg and 19-20 “Hg at the adjusted setting.
  3. #53
    Louisville, KY
    turbo m3
    Me too, why not...
  4. #54
    '97 M3
    Okay, that would be 3 degrees retarded on the intake and 9 degrees advanced on the exhaust then.
    I found the angles for the top of the Schrick cam squares relative to the valve cover surface. Assuming that the squares are square the numbers jive (+/-).
  5. #55
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by chikinhed View Post
    Perfect, the angles at the camshaft are 1/2 of the actual lobe center angle change so twice your numbers would be 3 deg retard on the intake and 9 degrees advanced exhaust as my tools are marked. I have these ready for whoever wants to try this timing. Just PM me.
  6. #56
    Toronto, Canada
    E36 Turbo
    Bam! Group hi-5!
  7. #57
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Quote Originally Posted by NOTORIOUS VR View Post
    Bam! Group hi-5!
    Lol yup!!
  8. #58
    Bellingham, WA
    e30
    I love it when a plan comes together!
  9. #59
    Feb 2016
    Rogers AR
    1995 BMW M3
    Quote Originally Posted by wazzu70 View Post
    I read that as Hannibal from the A-Team lol
    agreed though
  10. #60
    Bellingham, WA
    e30
    Quote Originally Posted by lbennyboobool View Post
    agreed though
    As you should
  11. #61
    Bellingham, WA
    e30
    http://www.catcams.com/media/documentation.aspx
    The above link has some good information on camshafts, cam timing, how to read lobe profiles, etc. On the site it also lists out the cams available for the various engines and gives full details of what the profiles and lobe centers are for the different grinds.
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  12. #62
    Z3speed4me's Avatar
    Z3speed4me is offline Coupe Cartel Forever! BMW CCA Member
    Apr 2002
    Westfield, NJ
    MCoupe, Q3, Tiguan
    So has anyone else tried these new timings on their 264/256? Before and after would be nice.... Interested in throwing a set in my car but not being the tester.
    ~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
  13. #63
    Apr 2006
    Minnesota eh?
    86 325es
    I remember sending out a couple sets of blocks for these settings, but I didn't get any feedback. I would love to hear any results good or bad.
  14. #64
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I have not yet re-timed. Maybe soon.
  15. #65
    Mar 2013
    Upstate NY
    M3
    Yeah, someone give me a reason to pull the valve cover the 10000 time
  16. #66
    Jun 2005
    New England
  17. #67
    Bellingham, WA
    e30
    Hi5
  18. #68
    '97 M3
    In for results.
  19. #69
    Jun 2005
    New England
    Seems good to me but I have no way to data log so I can’t confirm Chikinhed’s measurement of slightly less time to boost. I wish I could say my butt dyno was well enough calibrated. I was not expecting anything dramatic — my car is already pretty responsive with 3.2L, 0.92 EFR 9180, twinscroll Steedspeed, eBoost, and mild Schrick 264/256. I certainly won’t be setting cam timing back to stock.
  20. #70
    Raleigh, NC
    1993 525iT/5, 1998 M3
    FYI i bought a set of Perry's blocks and will be trying them out on my GT35R M3 once the engine is done at the machine shop and i have time to gap rings, re-assemble, re-install, etc.
    I plan on timing it with the blocks to start, and can get idling vacuum numbers if that helps, but then I will be taking it to the dyno for troubleshooting. once running right, i'll retard the exhaust 8 degrees and advance intake 4 degrees. will try to report results. thanks again Perry and all that contributed!
  21. #71
    '97 M3
    Often I find a reduction in power is easier to feel than an increase.
  22. #72
    Apr 2006
    Minnesota eh?
    86 325es
    Any more impressions after driving some more? Worthwhile mod or should people leave them at stock timing?
  23. #73
    Feb 2016
    Rogers AR
    1995 BMW M3
    I feel like him saying "I certainly won't be setting cam timing back to stock" as a worth while mod, but then again it could be my optimistic interpretation. Could be "not worth doing it again"
  24. #74
    Jun 2005
    New England
    I trust Chikinhed’s testing, which showed an improvement in spool. He and I both have built S52s with Schrick 264/256, twinscroll steedspeeds and EFR9180s. Unfortunately, I do not have a baseline dyno that I could compare to or data logs. My car was already very responsive and my butt dyno simply is not well enough calibrated to notice. I certainly don’t think it’s any worse and based on Chikinhed’s testing believe it is better. I have no plans to change timing back.
    Someone else with data logging ability or a baseline dyno could give a better review. Maybe someone with a laggy turbo would be able to notice a difference without any testing. Probably the results would vary depending on the turbo, the motor, the manifold, etc. And this cam setting is what Chikinhed found worked best for Schrick 264/256 through degrees g various settings and data logging. Other cams might require different settings.
  25. #75
    Louisville, KY
    turbo m3
    I wonder how these would work on Luke’s (Gt35rM3) old setup, which is mine now. I need to look up all the old data. But, I think they were M3jasper’s custom setup that he marketed while he was selling built short & long blocks.
  1. E36 E36 M50,s50,m52,s52 lifters / cam followers
    By rmxr3 in forum Engines, Performance Parts & Software
    Last Post: 01-21-2015, 09:15 AM
  2. M50, S50, M52, S52 turbo manifold - NEW
    By DrOtto in forum Engines, Performance Parts & Software
    Last Post: 09-30-2008, 05:40 PM
  3. F/S or F/T partial e36 m50/s50/m52/s52 turbo kit
    By vdrm3 in forum Race Cars & Track Parts
    Last Post: 01-27-2007, 09:49 PM
  4. Fs: M50/s50/m52/s52 E36/z3/e46 Fan Clutch!!!
    By HOOJ in forum BMW Parts For Sale
    Last Post: 12-13-2006, 03:02 AM
  5. E36 m50 s50 m52 s52 oil pan , no dents .
    By hyepwr in forum BMW Parts For Sale
    Last Post: 08-14-2006, 06:57 PM
