Results 1 to 11 of 11
Thread: Coolant leak
    Nov 2017
    Stockton, CA.
    None
    Coolant leak
    I'm looking into buying a 2003 540i 6speed and the seller states the car leaks coolant when pushed hard. Claims it's the o rings on the metal tubes that goes to the engine. Could it be that or the valley pan leaking?
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    When "pushed hard"??? That doesn't even make sense.
    Without more information, the leak could be from almost anywhere.
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
    Nov 2017
    Stockton, CA.
    None
    Quote Originally Posted by Santaclaus4 View Post
    Yes that's what I thought as well here's a screen shot of what he said
    Jan 2016
    Ca
    2001 525it
    Pre purchase inspection
    May 2014
    Yea, his text wasn't super helpful. I'm still trying to figure out what "pushed hard" means in his context. It sounds like he's not very mechanical and doesn't understand what could be wrong. If he had the cooling system apart and noticed a bad O-ring and didn't replace it, he's pretty lame (insert your derogatory word here).
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    You mean a mutherfluffing idiot, right? Just wanted to make sure.... Ok, ok.... move on, nothing to see here....
    May 2013
    central Va
    for his asking price..... he should pay for a PPI
    Nov 2017
    Stockton, CA.
    None
    Quote Originally Posted by riverdadd View Post
    You seen the car listed before?
    May 2013
    central Va
    Quote Originally Posted by xBOOGx View Post
    sorry for the delay, site was down and my job happened!
    I know nothing of this car other than what you posted here and other threads. You stated the guy wanted 14k firm, my point was , at that price he should have a PPI and carfax and finance the loan!
    Feb 2014
    Alexandria, VA
    That guys on drugs..... Move on. For a good well maintained ‘03 540 with a stick that doesn’t leak, has a good maintenance record, below 90,000 miles, you should be in the 8 to 9 grand territory.
    NW suburban Chicago
    hiss by my window
    He states that when replacing the radiator he noticed the o-rings were " a little worn out". #1, those seals are not in any proximity to the radiator. Second they are not visible at all until you do some dismantling.
    I'd want to know if the leaking is accompanied with overheating"when pushed" and why the radiator was replaced.
    Perhaps just a case a seller not knowing his ass from a hole in the ground but if I were you I'd run from any BMW with nebulous cooling system issues unless you are qualified to diagnose it on the spot before purchase or prepared for the worst.
    Comments by others also indicate a high price so..........
  1. Ack, coolant leak....
    By MidnightBMW in forum 1991 - 1999 (E36)
    Last Post: 05-05-2003, 07:45 AM
  2. Coolant leak
    By mdibatti in forum 1991 - 1999 (E36)
    Last Post: 12-12-2002, 08:13 PM
  3. odd coolant leak
    By BCMike in forum 1983 - 1991 (E30)
    Last Post: 09-07-2002, 11:09 PM
  4. Internal coolant leak on my 91 318is
    By cohiba in forum 1983 - 1991 (E30)
    Last Post: 05-03-2002, 01:59 AM
  5. Coolant leak problem
    By fstbmwm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-19-2002, 10:04 AM
