We have completed the development of the BMW M2 M3 M4 intake system that is dedicated to the S55 3.0T engine. This intake kit includes a 3" intake pipe, an engine heat shield that helps block hot engine air, a MST high-flow air filter and easy to install.
We also did the Dyno testing, the maximum increase is about 10-13HP, the throttle response is better than the original air intake,and there are more exciting sounds. After installation, it can be upgraded to the original power programming or Stage 1-3 programming.
Features
- * Maximizes airflow to provide gains of 10-12 HP!
- * High quality laser cut heat shield helps block hot engine air
- * Better throttle response and more exciting sounds
- * Can be upgraded to the original power programming or Stage 1-3 programming
- * High-flow air filter, easy to maintain
Fits
- BMW S55 3.0 Engine M2/M3/M4
