Results 1 to 5 of 5
Thread: Ignition delay
    Jan 2020
    Perth Australia
    BMW 635 CSi 1985
    Ignition delay
    Hi, 635csi (Euro RHD) ... rego says 82 but everyone tells me they did not make them in 1982?? anyway, currently mid-restoration but coming across a problem I was having when I was last driving her, in that..
    When I turn the key, dash lights up etc but when I turn all the way to crank I have to wait 2 - 5 seconds before anything happens, then she cranks and off we go.. the delay is always at least 2-3 seconds and sometimes longer.
    I have replaced the fuel relay next to the fusebox and another random relay next to that for good measure, prior to changing those the delay was much worse and sometimes would not crank at all and had been resorting to shorting the solenoid next to the fuse box to get her started.
    Any ideas ? its kind of annoying.
    Also off topic, sort of, I am so used to keyless ignition these days I was wondering if anyone had retro-fitted keyless and push-button start to an old girl like mine ? any links appreciated.
    Cheers!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The EURO 635CSi RHD was available from 07/1978 - 04/1989 http://bmwfans.info/parts-catalog/E24/
    West Nyack, New York
    86 635csi 98 740i 96 MB
    I can't remember why but many years ago I installed a push start button,
    when I finally sorted the problem back it went to oem.
    This is not key-less.
    https://www.summitracing.com/parts/r...+5ba2974bb4c03
    These are
    https://www.jegs.com/p/Ididit/Ididit...46378/10002/-1
    Brockton, MA
    1985 bmw 635csi
    I had a similar issue, I thought it was a starter issue but it ended up being the ignition switch at the back of the key cylinder , the plastic had cracked and it was not making full contact. I would try that first. https://www.ecstuning.com/b-genuine-...h/61321377105/
    Pino
    Pino
    1985 635csi
    Brockton, MA
    North Central Florida
    88m5,2015 Silverado
    As Pino suggested, replace the electrical portion of the switch
  1. Delayed response when turning the key (ignition)?
    By S.Hafsmo in forum 1995 - 2001 (E38)
    Last Post: 06-28-2013, 12:44 PM
  2. New HID ballast has a slight delay igniting.
    By fixture in forum Lighting sponsored by BAVToys
    Last Post: 10-22-2007, 10:53 AM
  3. Potential Ignition problem? Delayed startup?
    By surfinsd in forum 1992 - 1999 M3 (E36)
    Last Post: 07-17-2005, 07:50 AM
  4. Need ignition switch power wire
    By Cindy in forum 1992 - 1999 M3 (E36)
    Last Post: 05-28-2001, 10:27 PM
  5. Replace ignition leads at what mileage
    By Miles-uk in forum 1991 - 1999 (E36)
    Last Post: 04-11-2001, 10:46 AM
