Results 1 to 9 of 9
Thread: M135i rough idle
    Aug 2019
    Europe
    M135i
    Post M135i rough idle
    Hi guys,
    I am in desperate need of help to diagnose my m135i n55 engine rough idle issues. Car has 83k km. Plugs were replaced at 60k km with OEM and the car is completely stock. I can feel the misfires at idle and on light throttle when the car is cold (hesitating) but there are no error codes and I have no idea how to continue.
    What I've done until now:
    - I've bought an coilpack and moved it over all cylinders, no difference.
    - Pumped 2 botttles of European Chevron Techron fuel injector cleaner. Seemed to smooth things a tiny bit but I am not sure if it was placebo or different fuel that caused this
    - Tried different fuel stations
    I got BMW INSTA and recorded some parameters at idle and at about 2-3k rpm where the imbalance can be felt best. Rough running values seem to be all over the place and I can't pin point what cylinder is faulty. Misfire counters indicate 0 for some reason, although there are misfires almost each second.
    Rough running values at idle:
    https://www.youtube.com/watch?v=bWiUI0dPozo
    Rough running values with throttle input up to 2-3k rpm:
    https://www.youtube.com/watch?v=-Mt69SrIPEw
    Engine knock sensor values on idle seem off:
    https://www.youtube.com/watch?v=4UUDaMn0k8A
    Ignition timing is fluctuating 4.5 to 6.75 (is this normal?)
    O2 after cat is 0.82V
    O2 before cat 1.47V
    If any of you have any ideas on how I should proceed I am eager to listen. I've been waiting for this issue to get worse so that it can finally throw an error code but it's already been months and although it seems to be a bit worse, seems it's still not bad enough for BMW technicians.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The first step in diagnosing a problem is to scan the engine computer (DME in BMWspeak) for codes. You’re getting too deep in the weeds. Scan the DME and post the codes. I bet you have vacuum leaks.
    Aug 2019
    Europe
    M135i
    I wish it were that easy. I did run a scan but had no engine related codes.
    Jan 2016
    Ca
    2001 525it
    I'd start looking at injectors, but you may need a more advanced diagnostic reader like the kind shops have auto logic or Ista to run tests
    Aug 2019
    Europe
    M135i
    Quote Originally Posted by jclausen View Post
    I am already using BMW INSTA which I suppose they also use in the dealership. As I said in the original post, the DME misfire counters all indicate 0 and I don't understand why. I am also thinking about the injectors, but they all seem to run in accepted parameters at idle. I am not eager to replace all of them without being sure this is the fault since they are quite expensive. I am not sure what others tests except rough running values and misfire counters I could try.
    How could I further diagnose the injectors? I already took 2 plugs out (cylinder 5, 6) and they seemed clean (no fuel/oil smell) and with normal uniform wear (very little because only ~20k km on them). I am thinking about taking rest of plus off and check their state.
    Does anyone know why my DME misfire counters seem to not be working? They all indicate 0 and I can't belive that.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    No codes? That’s odd. I’m wondering if you have vacuum leaks. Can you check on the operation of the pre-catalytic converter oxygen sensors? They trigger lean codes P0171/0174.
    Aug 2019
    Europe
    M135i
    Quote Originally Posted by MarcoZandrini View Post
    1,48V before cat
    0.82-0.83 after cat
    Feb 2020
    Indio, California
    2012 135i
    Any update on your progress?
    Aug 2019
    Europe
    M135i
    Unfortunately I have no progress, so if anyone could share some advices I'd be grateful.
    I felt like it's been getting worse, so I plugged in my INSTA again and checked the injector corrections. Seems that all injectors apply a negative correction, values are all over the place but in the accepted interval, so still not triggering a code. I am a bit puzzled. This seems to not be a particular cylinder issue so I was thinking there is an air leak, but in this case shouldn't the corrections be positive? Considering more air si getting in than detected by the MAF?
    Oh, the after cat voltage values seem to move a bit more on my last checkup, so again my feelings that it's getting worse are confirmed...
  1. Rough Idle Q's, and SF Stealers
    By C.Yang in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2001, 03:26 AM
  2. Rough Idle
    By daytonflyer53 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-05-2001, 09:42 PM
  3. Help! Rough Idle
    By dakowals in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-04-2001, 11:35 PM
  4. Rough idle issue
    By jayhudson in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2001, 11:04 PM
  5. Rough Idling
    By jaramill in forum 1992 - 1999 M3 (E36)
    Last Post: 04-13-2001, 10:10 AM
