Hello,
I have a lot of Toyota 5W-30 1WW/2WW engine oil and I was wondering if putting it in a BMW 435d can be bad for the car. The oil is made for Toyota 1WW/2WW engines which are based on BMW N47.
I’d be happy to hear your thoughts.
Here is what I found:
Toyota Genuine Motor Oil Fuel Economy SAE 5W-30 surpasses the following international petrol and diesel engine oil performance standards and approvals:
- Certified against ACEA A1/B1-04
- The oil has the performance level of ACEA A3/B3-04
- Meets the API SL/Energy Conserving
I guess it should be ok?
No, this motor uses 0W30 LL12FE. Just use the correct oil.
Mark.
You definitely need to use an oil that's rated for diesels.
