What are you running in your car and how happy are you with the lighting choices youve made.
Looking to upgrade the useless stock units with glass angel eyes and hid.
Asking for a friend...
2002 BMW M3 Convertible - Imola Red
2005 Ram 1500 HEMI Laramie AWD
1997 BMW M3
IMO, angel eyes look stupid, they've been played out years ago. Also if you do get angel eyes it will be difficult to get all the color temps matched up between all the other lights, and if not done right it will look like a rainbow.
Depo projector lenses are a good way to go:
https://www.ebay.com/itm/DEPO-Glass-.../324004897348?
2D with the corner lights:
https://www.ebay.com/itm/DEPO-Glass-...e/152880776524
4D sedan with the corner light
https://www.ebay.com/itm/DEPO-Glass-...id=13018086003
They need H1 bulbs, get either 5000k or 6000k color temp. If you get funky colors you will just get pulled over, especially if your in NY. In my town you will only see someone with pink/green/purple lights once or twice, because they were forced to change them lol. I"ve used this brand and its been reliable:
https://www.ebay.com/itm/9005-9006-5...s/371939194675
Stupid? Ok, sure.
I’m not looking to get anything from eBay, I’ve had horrible experiences and usually zero support after the sale and not that hard up to save a couple of $$.
Thanks anyways.
1997 BMW M3
Okay then here ya go:
https://store.vacmotorsports.com/vac...yes-p2235.aspx
ZKW w/ HID.
CARS
02.92 325is / 06.72 2002 / 02.91 XJ / 08.04 R53 JCW
I have some HIDs from a place in California called DDM. They have complete headlamp units that are focused pretty well, and the lights work good. I have both Low and High beams in an HID, but the high beams take time to warm up so using them to flash other cars or trucks is no longer a thing. If you want to flash a truck to give it the lane, you have to hold the flasher switch for a few seconds to warm the bulbs up, then you can flash.
Put these on my 97 vert two years ago when i swapped the motor. Very bright and they actually came with bulbs installed .
For $100 is a fair price - nothing fancy
Sent from my SM-N950U using Tapatalk
This car is AWESOME !!!
OEM Bosch H7 halogen non-projector units. The later OEM fitted units.
Very happy with them. Beats the HID's H1 light of my 328i's ZKW H1 projecttor units.
I'm running depo headlights with morimoto FX-R projectors. They are D2 bulbs and very bright and clear. I have actually cut the centers out of my inside lenses to stop them from blocking the etching I had done on the lenses.
Sent from my SM-G965U using Tapatalk
I bought Apexcone headlights from DDM tuning with 55w 6000K bulbs. Not really happy with them, high and low beams aren't even close to pointing in the same direction. Disconnected the high beams and the lows are bright enough even with the dark Lamin-X film on the lenses.
Buy a set of OEM Glass ZKW or Bosch from @Misskitty in this thread - https://www.bimmerforums.com/forum/s...-tails-corners
Thats what im doing next month, Nothing will really compare to OEM.. If I was to go aftermarket it would be Depo replica oem lights without angel eyes, They really are not period
correct on the E36.. Its my opinion so def get whatever you like but I dont think they fit the style of the car that well esp in 2020.
13 F30 328i Sport 6MT
95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread
08 E90 328i Sport [sold]
89 E30 325is [sold & missed]
Not only are angel eyes period incorrect, they also look awfully bad on the E36 regardless.
I had a set of Bosch ones shipped from the UK, with clear corners, sides and tails all BMW for like 350 or so.
ZKW or BOSCH.
www.umnitza.com - take your pick customize them with morimoto parts or whatever you want, we build it for you.
DIY Youtube Videosumnitza.weebly.comUmnitza Instagram Umnitza Facebook
Join Our Facebook! - Check Out Photos, Talk to Customers, Ask Us Questions!
Call US 877 486 6489
Available: 9am-5pm M-F
