Results 1 to 5 of 5
Thread: Lock nuts for lower steering column
    Sep 2018
    Houston, TX, USA
    1999 BMW Z3 Coupe 2.8
    Gents, anyone know the lock nut size on the lower steering column? (1999 z3 2.8)
    Greyed out on realoem.com:
    https://www.realoem.com/bmw/enUS/sho...diagId=32_0915
    Getting a last round parts order together for the front end refresh
    Nov 2016
    Oklahoma City, OK
    2000 BMW Z3 2.3
    The diagram is incorrect - there's not actually a nut that secures the end of that bolt on the lower steering column. There's just the bolt, and the pinch joint it goes into is threaded for it.
    I recently did a front-end service that involved disconnecting the column, and I just cleaned up the bolt and torqued it back into place.
    Sep 2018
    Houston, TX, USA
    Quote Originally Posted by Schreier View Post
    Sweet. One less fastener to buy. Thank you, good sir
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by solimans View Post
    Tip on putting it back together right; I always put a center-punch mark at the split in the u-joint before taking it apart, to make lining it up easier (you'll need to leave the column unlocked to put a socket on the bolt). If the column doesn't readily separate from the u-joint, a wedge driven in the split__with caution__will open it up for you.
    You can also see the fastener for the threaded end of the bolt__it stays in place, but I always have used red Loctite when reassembling it (@ 23 Nm).
    Sep 2018
    Houston, TX, USA
    Quote Originally Posted by Randy Forbes View Post
    Thank you, Randy. Makes me feel more confident going into this job
  1. FS: Lower steerring column pads NEW
    By bluedevils in forum 2002
    Last Post: 02-15-2009, 09:19 PM
  2. Pics of lowered steering column and new steering wheel
    By RingoZabel in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-26-2008, 02:30 PM
  3. Pics of lowered steering column and new steering wheel
    By RingoZabel in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 10-31-2008, 11:26 PM
  4. WTB, E34 lower steering column for 5 swap
    By Hanselhoff in forum BMW Parts Wanted
    Last Post: 03-24-2008, 10:38 PM
  5. diy: lowering steering column
    By ltw97m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-15-2007, 08:24 PM
