Hey guys,
I plan on doing a full cooling system refresh next week and I want to do the electric fan conversion but I'm a little nervous. I feel confident I have the skills for the job, but it would be easier with two people. That said, I need to make an 8 hour drive to my buddy's shop where we plan on doing the chain guides and some tranny/clutch work. Here's my dilemma, do I:
1) Just replace my water pump, radiator, and hoses. Reuse the old fan and fan clutch and make the 8 hour drive, hope nothing explodes, and do the electric conversion with my buddy who has way more skills than me and has already done it to his E46. OR...
2) Replace everything, do the electric fan conversion, and call it a day. Then have to remove everything again to get the engine out and probably replace the upper and lower radiator hoses again because I'm pretty sure I shouldn't install them, run them for a while, take them off, then reinstall them. Something tells me that's just asking for leaks. This is the most time consuming and expensive option, but obviously the safest. OR...
3) Risk the drive with my water pump going out and adding coolant once a week (bad idea) OR...
4) Just do the water pump and do the rest of the job with my buddy when the engine is out.
5) or? Maybe you have a better idea.
I what I am asking is, what is the best way to do this without having to do part of the job twice while still being fairly confident I won't blow anything up?
Thanks!
For a DIY'er, I'd go with Option 2. And no, it will not leak if you do it right. Replace the radiator hoses as well.
Sure, you'll have to tear down the engine again if and when you do the guides. But that is an entirely another job and really not necessary in my opinion as long as the guides did not break...
As to the clutch, you'd have to pull the transmission anyway.
rent a truck and trailer??
Since I can do everything myself, I do it once, properly, DONE!
So what if I don't change out the fan and fan clutch? Just the radiator, water pump, hoses, thermostat, expansion tank, cap, etc.? Will the old fan and clutch be okay? Then I can drive it south and have some help with the conversion? Honestly, I am a little concerned about putting in an electric fan right now because I have some weird electrical issues I am trying to fix and I am afraid the additional strain it would put on my electrical system might be bad.
That would be fine. Why do you feel the need to change the fan and fan clutch ??
"If it ai'nt broke, do not fix it"....!!
Current stable:
2002 525i (Daily Driver)
1994 SN95 Mustang 'Vert (The Bumblebee)
2001 325i Convertible (Beach cruiser project)
Jeez, if it’s that much of a concern, don’t reinstall the fan and clutch. You can drive the car no problem without them, hell, you can even wait a year or so if it fits your schedule to wait, before you drive it to your buddies shop. Lots of guys run their cars without the setup.
as long as the aux fan stays operational...if it doesnt...then...blammmo
I vote #4, just do the water pump for the moment. It's winter, the cooling system won't be taxed hard, you could even run without the fan for the moment as long as the aux works now.
But I would not attempt it with a leaking water pump. You're local to me so you can follow on locations. Long ago I had a Bavaria. The water pump just started to leak a little bit, just a little. We decided to take it to Reno for the weekend, living in Cotati at the time, without changing the WP. It was leaking pretty bad in Sac, but I pressed on. Made it halfway up Donner summit. Water was just pouring out by then less than 200 miles later. It probably wouldn't happen to you, but it might. Of course my situation was complicated by an intermittent temp gauge, but still. Don't try with a leaky water pump. It might go that way for years, or it might be hours.
98 328is
02 525ita
80 528i
81 528ia
and decades of owning and driving BMWs
water pump leak could be caused by a seal problem, or a shaft bearing problem. if shaft bearing wont last long, with a seal problem youre just playing the odds...not with good numbers.
If nothing is leaking do it all at once at you buddy's shop
Sure did! Boy, that one was tough to figure out. I owe you a ton of thanks for your help with that car back in the day. Since it was such a weird combination of different models and almost no information out there. Your E21 experience helped a lot. Good to see you still cruising around the forums, offering your expertise!
