Results 1 to 4 of 4
Thread: Sunroof Drain, Weather Stripping, or Something Worse?!
    Dec 2019
    Vancouver, WA
    2000 528i Wagon
    The last couple days, my dash has dripped water on me on the driver's side. Between the drips and the water I track in from the rain, it's hard to say exactly how much is leaking in, but every time I turned it dripped some more.
    Then, this morning, I felt a drop on my thigh, which I dismissed at first because it seemed absurd from that high up, but then I felt it again, and so I looked up, and sure enough, there's a nice dark wet spot at the top end of the pillar, actively leaking water.
    Is this an issue cause by the sunroof drain needing cleaning, or is it a weather strip thing? I haven't opened the sunroof since I got the car because we've been so out of season, but this is also the first car I've had with a sunroof, so I'm inexperienced in their issues/maintenance.
    I'm looking at a post from 2009 regarding weather stripping, but didn't want to assume that was the only possible issue. I took a picture; hopefully it shows in this post.
    Thanks in advance!
    NNJ/NYC
    1997 528i/5, 1997 528i/5
    Open the sunroof and use weedwhacker lines or an air compressor to blow it out. Then you nee dot undo the grab handle and sun visor to pull back the headliner to confirm the sunroof drain hasn't come unattached from the sunroof cassette.
    Wade
    Jan 2016
    Ca
    2001 525it
    Believe me when I tell you it's either sunroof drains or the door vapor barriers but since it's on your leg it sound like sunroof drains, very common
    Dec 2019
    Vancouver, WA
    2000 528i Wagon
    Thank you, will do!
    Quote Originally Posted by jclausen View Post
    I appreciate the help narrowing it down, thanks a lot!
  1. E36 Sunroof, complete system, front fenders, bluem door weather stripping
    By raamaudio in forum Exterior Lighting & Body Parts
    Last Post: 09-25-2013, 10:19 AM
  2. Part# for sunroof headliner/ black weather strip
    By HFe36 in forum 1991 - 1999 (E36)
    Last Post: 09-08-2010, 10:05 PM
  3. Where to buy sunroof weather strip trim.........
    By 740ibimmer in forum 1995 - 2001 (E38)
    Last Post: 08-15-2008, 03:44 AM
  4. WTB: Weather stripping and manual sunroof crank
    By mischief3003 in forum BMW Parts Wanted
    Last Post: 09-20-2006, 09:23 PM
  5. Wtb: Weather Strippings!
    By IMAGE&STYLE in forum BMW Parts Wanted
    Last Post: 01-06-2003, 10:55 AM
