Results 1 to 15 of 15
Thread: BMW Coolant.
    Sep 2010
    Corpus Christi Texas USA
    850ci, M5, Alpina B7
    BMW Coolant.
    Does BMW coolant stay blue or does it become greenish after being in the cooling system?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It stays blue!
    My BMW Repair YouTube Channel
    Sep 2010
    Thought so.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    The only thing green about using BMW coolant is the extra cash you will be spending for it...
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    May 2019
    Grovetown, GA
    1991 850i 6-speed
    Quote Originally Posted by TxGR8White View Post
    I swear I read elsewhere on this forums that the $$$ BMW coolant was recommended. I guess I spent more than I needed to on the 'good' stuff. Good to know that I can save cash on my next coolant flush.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Why use anything other than BMW coolant? It has the correct plasticisers, corrosion inhibitors, lubricants and preservatives for our engines - and it costs a tenner for 1.5 Litres (part number 81229407454). It really isn't worth a punt just to have the plastic bits disintegrate and the water pump to seize up!
    May 2019
    Grovetown, GA
    1991 850i 6-speed
    So BMW coolant is recommended for a reason for our cars? If so I'll keep with it. Thanks Timm
    Dec 2007
    Dallas, TX
    I have been running PRESTONE 50/50 in my 850Ci for the past 125,000+ Miles and have had ZERO issues. I did replace a radiator due to FOD from the highway, but am still on the same expansion tank and second water pump (bearing gave out on that one).
    Advantages:
    1. Available EVERYWHERE
    2. costs 1/3 that of the BMW coolant (no BMW “surcharge” for branding)
    3. It glows in the dark
    The important thing is to make sure you do preventive maintenance (which most owners do not do), and flush the system in intervals as described in the manual (drained and refilled every two years). The manual also states that you should use “antifreeze concentration of at least 50%, no where does it specifically state to use the blue stuff.
    Feb 2015
    Kuna, Idaho
    Too Many Cars (NOT!)
    Somewhere in all my wanderings, I ran into a post that made an excellent case for Zerex Z06 as it was (theoretically) the same chemically as BMW Blue, but YMMV. Been using it in ALL the cars except the truck and Dart and no problems.
    Mike Drives:
    BMW's
    E24 - 635CSiA - (1) 1985 (US)
    E24 - 635CSi - (1) 1985 (EC)
    E31 - 850iA - (1) 1991 (Black)
    E31 - 850iA - (1) 1991 (Calypso Red)
    E32 - 740iA - (1) 1994
    E32 - 750iA - (1) 1990 (Not an "L") (EC German National)
    E32 - 735iL - (2) 1990
    E32 - 750iL - (1) 1990
    E38 - 740iLA - (2) (1) 1997 & (1) 1998
    E38 - 750iLA - (1) 1998
    E38 - 740iA - (1) 2000 "Short Sport"
    E39 - 528iA - (2) - 2000 & (1) 1997
    Also:
    2015 Ram 3500 Dually, Cumins 6.7, Std.Cab. Long box 4x4 (To haul all this junk when necessary)
    2014 Dodge Dart Rallye (Daily Driver)
    2007 Mercedes Benz CL600 (Brabus SV12S)
    Mercedes Benz SL's - (1) (2002) & (1) 1999 500 - (1) 1999 600
    1967 Buick Riviera (2)
    Dec 2010
    Toronto, Ontario, Canada
    Bombardier subway train
    I don't see the problem with the BMW coolant. It costs twice as much as the others, AND it comes concentrated so you'll have to dilute it and end up with twice the amount as the others.
    So at the end it costs the same as everything else, and the brilliant engineers already did the job for us so why mess with it.
    Aug 2019
    Tujunga, CA 91042
    850CI740Lsezd750L95sezd
    Well I guess that depends how much you value your dog. The BMW blue stuff has a bittering agent in it, so that if it blows out and drips in your garage and your dog goes in there, the dog won't lick it up and die of kidney failure.
    Now you know.
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by CD05001CIA View Post
    Well I guess that depends how much you value your dog. The BMW blue stuff has a bittering agent in it, so that if it blows out and drips in your garage and your dog goes in there, the dog won't lick it up and die of kidney failure. Now you know.
    Interesting!
    1993 850Ci.....18 years & 165,000 miles and counting!
    Dec 2007
    Dallas, TX
    Now you know.
    my dogs have no way of getting into the garage, as they lack opposable thumbs with which to open the door. Also, have never had any of my vehicles leak coolant in the garage...
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    Whatever you do, don't mix coolants, they do not mix well and can cause issues. If you change coolant types, drain the block and radiator, then flush.
    My 850 came with green, has had green without issues, but will be flushed out for blue when changing it next. All the other cars in the house have BMW blue and its simpler to keep one type on hand.
    Regards,
    Brian
    Cave Creek, AZ
    Nov 2008
    Maryland
    not enough
    Quote Originally Posted by bdiefAZ View Post
    What Brian said. 850 came and is kept with green coolant. CSi came and is kept with oem BMW coolant. Neither has had out-of-the-ordinary repairs done. Just the normal wear and tear (expansion tank on 850, cracking radiator plastics on CSi).
    CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
    CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
    My other projects:
    Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
  1. BMW coolant not so special after all.....
    By back_in_black in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-22-2008, 09:46 AM
  2. BMW Coolant?
    By paul e in forum 1992 - 1999 M3 (E36)
    Last Post: 03-13-2003, 09:37 AM
  3. BMW Coolant online source
    By Kenshiro in forum 1992 - 1999 M3 (E36)
    Last Post: 12-10-2002, 01:15 PM
  4. BMW Coolant ?
    By mdv in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-08-2002, 06:58 PM
  5. Bmw Coolant Does It Really Matter
    By M3D in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-29-2002, 09:33 AM
