Has anybody found the proper tool for getting these out?
I've tried a variety of things including the 'Advance million piece loaner tool' and can't find anything that diameter.
Would rather not have to cut and otherwise maul the trailing arm to get them out and they are definitely in need of replacement.
Thanks all!
-Larry
Erwin did it: Trailing Arm Bushings - 20 Tons is not enough http://www.bimmerboard.com/forums/posts/503785/
"So on Friday I went to Great Hills Automotive. They aren't BMW specific, in fact the shop was full of vintage corvettes, a cobra, and assorted other muscle cars, but they have a reputation for excellence and honesty. The guy there said he could do it in an hour, no problem ($85/hr), but not today, has to be Monday. Then he went on to mention he wouldn't use a hydraulic press at all, but a c-clamp ball joint press, and that he would freeze the bushings first to shrink them. Really? Yep, 2 hours in the freezer, some anti-seize, and they go right in. He told me this fully knowing I might go try it and not come back. He was right. Turns out you don't need tonnage, just a $30 tool, and some cold air" http://www.bimmerboard.com/forums/posts/507089
trailing arm bushings dimensions http://www.bimmerboard.com/forums/posts/506762
