Technique Tuning (TT) Stage 2 Supercharger tune with 413 ecu
This is an original technique tuning chip with encryption board and good 413 silver label ecu. Many people consider this the gold standard in tuning.
This tune is for a stage 2 supercharger kit so upto 11psi. It would likely work fine for any supercharger kit with the correct maf and injectors. EWS deleted.
This tune is for use with 803 maf and 42# injectors
Feel free to ask questions. 350$.
Reason: forgot price
1989 535i - sold
1999 M3 Tiag/Dove - sold
