Results 1 to 2 of 2
Thread: Technique Tuning (TT) Stage 2 Supercharger tune with 413 ecu
    Mar 2012
    Renton, Wa
    98 m3
    This is an original technique tuning chip with encryption board and good 413 silver label ecu. Many people consider this the gold standard in tuning.
    This tune is for a stage 2 supercharger kit so upto 11psi. It would likely work fine for any supercharger kit with the correct maf and injectors. EWS deleted.
    This tune is for use with 803 maf and 42# injectors
    Feel free to ask questions. 350$.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    NY
    skateboard
    Interested in just the injectors
    ― George Orwell
  1. FS: Burger Tuning N55 Stage 1 tune
    By kaguirre579 in forum Engines, Performance Parts & Software
    Last Post: 03-01-2015, 11:48 AM
  2. FS: Burger Tuning N55 Stage 1 tune
    By ronnie0738 in forum Engines, Performance Parts & Software
    Last Post: 11-08-2014, 04:52 PM
  3. E36 RK-tuning 60lb S52 Supercharger tune OBD1
    By cj.surr in forum Forced & Chemical Induction Parts
    Last Post: 06-10-2014, 04:01 PM
  4. E36 OBDII TT stage 2 tune w/ injectors+ MAF and other crap
    By hellrot98m3 in forum Forced & Chemical Induction Parts
    Last Post: 05-23-2012, 09:28 PM
  5. technique tuning tt turbo kit e36 m3
    By j2smile in forum Forced Induction
    Last Post: 08-20-2007, 04:07 PM
