Results 1 to 15 of 15
Thread: 1996 BMW 318ti 4 Wheel Drive Conversion
    Jan 2020
    Frederick
    1996 BMW 318ti
    How would I do a
    4 wheel drive conversion to a
    1996 BMW 318ti with a Ford V8, and what parts would I need?
    Jan 2020
    Frederick
    1996 BMW 318ti
    I am also planning to raise the ride height by several inches.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I have been reading the forums for 15 years and this is not a common topic. Your project will be complicated by the V8, but I’d start by googling E36 AWD. You will find some leads.
    Oct 2016
    Austria
    e36 323i, M3 3.2
    probably best to try e46 or e30 awd parts. heavy modification will be necessary anyway.
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    Just give up. Might as well just make your own car out of scrap.
    Jan 2020
    Frederick
    1996 BMW 318ti
    For your information spyderg0d the car is in the most appalling condition any BMW has ever been in, in other words IT IS A TURD! So I am basiclly starting from a scrap heap with a VIN number.
    Nov 2013
    Oneida, NY
    Oh... In that case... Just scrap it and buy a 4wd car that has an adapter plate for a v8 to drop in.. Problem solved. Lol..
    Jan 2020
    Frederick
    1996 BMW 318ti
    I want to make this specific model/body style into a cool 4 wheel drive hot rod.
    Nov 2016
    Long Island, NY
    A few
    Sounds like a good Gambler 500 project. You may want to consider swapping the body onto a modified truck chassis.
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    Quote Originally Posted by Sweeney24 View Post
    How would I do a
    This is one of those times where, "if you have to ask..."
    Nov 2016
    Long Island, NY
    A few
    LOL touche ^
    Long Island, NY
    1995 M3 - 2007 X5
    Quote Originally Posted by JDStrickland View Post
    A lot of money would resolve the issue
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    The Ti rear suspension and subframe is basically the same as the E30 and can be interchanged quite easy. The E30 did have an AWD model (the iX). Front subframe and suspension differ slightly but if you can mesh the subframes together you may get away with running the E30 iX front subframe, transfer case, etc.. and E36 Ti front suspension bits. The E30 shares a steering coupler with the E46, which also had an iX version so you may need to refer fo that front subframe as well.
    Not sure the e30 iX stuff will hold up to V8 power, and it's also hard to come buy if you break something. Just something to think about. Maybe just 6cyl swap it using the E46 325iX as your basis for setting things up.
    mslevin's Avatar
    mslevin is offline Have you checked RealOEM? BMW CCA Member
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    Buy an old body on frame 4x4, cut up E36 body, place on frame. Connect steering and whatever else.
    Oct 2015
    Crystal Lake, IL
    1997 328is
    Would an early x3 front drivetrain be an option? I did see an x5 m54b30 with a 5 speed at the scrapyard this summer. This sounds kinda fun.
    Sent from my SM-G892A using Tapatalk
  1. 1996 BMW 318ti M Tech
    By minihoover in forum BMW Cars For Sale / Wanted
    Last Post: 03-01-2007, 09:23 PM
  2. A Bargain For Someone.Miscatigorized $400 1996 BMW 318ti in Toronto.
    By joe88 in forum BMW Cars For Sale / Wanted
    Last Post: 12-12-2006, 02:14 AM
  3. 1996 BMW 318ti, Priced to Move!
    By constant in forum BMW Cars For Sale / Wanted
    Last Post: 04-12-2006, 06:49 PM
  4. Front wheel drive conversion.
    By Robocop in forum 1983 - 1991 (E30)
    Last Post: 02-27-2006, 10:25 PM
  5. FS: 1996 BMW 318ti California Edition
    By tipsyaj in forum BMW Cars For Sale / Wanted
    Last Post: 08-08-2005, 05:07 PM
