Results 1 to 7 of 7
Thread: Radio Code
    Jan 2006
    Colton, Oreeeeeeeeeeeee
    Z3 and Z4 M Coupe
    Radio Code
    Is anyone here able to lookup a radio code ?
    My serial number is BP8272W1479433
    Part number 7648272042
    Location is USA
    Drink wine! BMW CCA #373875 - 2007 M Coupe (project) - 2000 Z3 Coupe - 2015 Impreza wagon
    Jan 2016
    Ca
    2001 525it
    Go visit the dealer parts department with the the w and numbers
    Feb 2004
    VA
    When I needed a code, the dealer for whatever reason could never supply the correct one. Two dealers in fact. I paid for an ivgsoft code and it worked. Think they may be even cheaper now like $7.
    Jan 2018
    Ocala, Florida, USA
    2001 Z3 Roadster 2.5 M54
    Funny I was looking at my Business CD radio on the work bench yesterday wanting to put it back in. Previous owner removed it because of the code issue, the code is currently unknown.
    So I searched for and found ivgsoft.com and it looks like 13 bucks will get me my code.
    Thanks for that info!
    Sent from my SM-J327V using Tapatalk
    Jan 2018
    Ocala, Florida, USA
    Just an update, I successfully installed my original Business CD and the code received from ivgsoft.com worked. When I first turned on the radio the readout on the radio said "CODE WAIT". I had to wait 1 hour with the radio on (found that info here in the FAQ) before that readout changed to "CODE _ _ _ _ _". Now I could enter the code, and the radio turned on.
    Also, the code entry instructions on the ivgsoft.com website did not work for my radio. Their instructions said to enter the first number of the code with the first radio preset button, pushing it the same number of times the first code number is. Then use the second radio preset button to enter the second number, again pushing it the same number of times the second code number is. Continue with the rest of the radio preset buttons until the code is correctly displayed. This did not work for me, so I simply entered the code using the preset buttons. So, if the code was 54326, push the fifth preset button once, push the fourth preset button once, push the third preset button once, push the second preset button once, and push the sixth preset button once. With the code displayed push the ">" tuning button to enter the code, and that worked!
    What I didn't do was put the alarm switch back where it belongs so the radio will not alarm if it is removed. The switch is there, ty-wrapped to the bracket, and apparently the aftermarket radio installer did something to keep the switch open so the Body Electronics Control Module thinks the radio is installed. My question is, what does the Body Electronics Control Module do when it thinks the radio had been removed? Does it send a signal to the EWS to immobilize the car?
    Thanks,
    Andy
    Denver, Colorado
    02 MRoadster / 435i
    The radio switch, behind the radio, is usually held in a open position (circuit not connected) by the rod sticking out the back of the stock radio. So that when the radio is remove, the rod is pulled out and the switch switch is closed and the alarm goes off (if set). You can either do something to hold the switch open (zip tie, tape, etc.) or just unplug the switch. This will allow your alarm to work with your radio out of the system.
    2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
    Jan 2016
    Ca
    2001 525it
    The z3 radios are a pain in the ass to code compared to the e34/36 type just have the radio on while driving and eventually the code wait will go back to code
  1. dealer can't find my radio code, where else can i go?
    By specialk in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-03-2002, 05:29 PM
  2. stock radio code help
    By cleoent in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-19-2002, 04:47 PM
  3. Radio Code
    By BRITISHmtrWRKS in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-05-2001, 02:33 AM
  4. need help finding out radio CODE!!!!
    By 232is PoWeR in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-17-2001, 01:33 AM
  5. Radio..."Code Wait"
    By JCM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-18-2001, 02:59 AM
