Hi,
Anyone using INPA on e36 ?
I'm trying to get INPA to work to use it on my e36 1997 euro spec 328i M52.
I keep getting the error "SYS 0005", and it says a SGBD file is missing.
So through googling i found the "fix" below. It says just copy the SGBD into the Ecu directory. But where are the correct SGBD for my e36 in the first place ? Copy from where ? The way they write just sounds it's obvious where they are, but do i need to download them somewhere ? Where do they come from ?
1.8 EDIABAS error: Error (95) SYS-0005: OBJECT FILE NOT FOUNDReason 1: No SGBD in C:\EDIABAS\ECUSolution 1: Copy the SGBD into the Ecu directory.
Reason 2: No group file in C:\EDIABAS\ECU (for group call)Solution 2: Copy the group file to C:\EDIABAS\ECU
Reason 3: No path definition C:\EDIABAS\BINSolution 3: Set the system variable (see 2.1)
Reason 4: Incorrect path definition in EDIABAS.INISolution 4: Set the EcuPath path in Ediabas.ini to C:\EDIABAS\ECU
Reason 5: The SGBD name contains reserved
solved by reinstalling windows
