Results 1 to 4 of 4
Thread: 14 328i problem/need insight
    Jan 2020
    California
    14 328i
    Looking for some insight/help with a problem, i have a starting issue with my bimmer, upon starting(50%) of the time, the starter stutters like the battery is dead....restart, and its fine, at times, when started, the first touch of the pedal brings revs down and the car smells like its loading, other times, it starts and runs like a new car....there are no codes...have replaced camshaft sensor/battery/starter/earth cable....its getting expensive and am looking for any help. Its a 14' 328i, it has start/stop function as well. Any responses would be killer at this time. Thanks
    Jan 2020
    California
    14 328i
    So, after a day in the garage....took all 3 fuse boxes out, cleaned with electrical cleaner....each fuse either replaced or hit with wire brush. Thats it, so much corrosion on the one under the hood especially, car fires and runs no prob, no misfire, hope this helps anyone. Cleaned all positive and negatives as well, (battery and under hood)
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    Thanks for the post. Sometimes going back to basics is the best approach.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Jul 2004
    Houston, TX
    36 Cylinders
    Now replace any broken shrouds and clear any drains. The fuse box should also be sealed well with its cover.
    Prevent another failure.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. 2011 328i Headlight problem need help
    By TahoeKen in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-08-2015, 06:59 PM
  2. E36 328is ignition problems. Need help fast
    By rybread765 in forum 1991 - 1999 (E36)
    Last Post: 12-16-2014, 07:43 AM
  3. 1998 328is problems. Need help.
    By Jwalton23 in forum 1991 - 1999 (E36)
    Last Post: 12-11-2012, 09:55 PM
  4. 96 328is electrical problem, need help
    By AU fan 06 in forum 1991 - 1999 (E36)
    Last Post: 01-21-2009, 02:54 PM
  5. Need Help Diagnose 328i problem
    By razorblade in forum 1999 - 2006 (E46)
    Last Post: 06-15-2008, 05:17 PM
