Car is mechanically sound, but needs a lot of love. I'm looking at starting a new business and need to cash out. I can sell as is or fix some things, but I want to throw this out there to get a feeler on the car with it's specs. If you have questions you can post here or email me at itsrichard (gmail).
Car is on it's 3rd engine (stock, Dinan swapped s50, current s52)
Chassis is 117k
Current engine sub 20k
Exterior
Work Meister S1 17x9 et 35?, 18x10 et20
235, 255
Painted black roof
Repainted Alpine white 3 2006 (Autowerks El Monte, CA)
PPM windshield (replaced 2006)
VIS carbon CSL boot (custom painted)
OEM boot (resprayed, no holes from spoilers)
Custom Depo + TSX projectors, euro relay for DRL, 4300 Phillips bulbs and ballasts
Clear tails
Rieger roof spoiler (black)
Interior
Race land pedals - black
M tech 2 steering wheel
Painted odometer rings
Race land steering wheel column gauges
Suede boot
Suede e boot
Arm rest
Rewired sunroof switch to center console
Hardwired for v1
11 button obc
Audio
Elemental Design amp nine
Elemental Design amp nine2
DLS Iridium 6.2
Denon DCT Z1 headunit (not working)
Engine
450rwhp/450rwtq
S52 obd1
JE Pistons
Pauter Rods
8.5:1
Gt35r82
O Ring HG
Upgraded studs
Castros Rebuilt head (less than 5k)
AA log manifold (heat treated)
Castros over subframe intercooler piping
Castros borla exhaust (v band)
HKS BOV
Tial 44mm waste gate
Sparco fmic
Manual boost controller in glovebox
Dual radiator fans
Dme flash tune (war machine)
Injectors
M&W CDI Ignition system
AA Meth injection (not plugged into system, but pump is installed and hidden under fender)
Custom Castro’s tig welded meth tank and custom windshield wiper tank
Defi boost guage
AEM AFR guage
Steering column dual pod
Stack center console guages: water, oil pressure, oil temp
Transmission
ZF 5 spd (new detents) less than 1k miles
AA ssk (New hardware)
Zhp knob
2.79 lsd less than 10k miles (probably less than 5k)
Reinforced stock trans mount
98 M3 axles (thicker than 95)
AA diff cover (powder coated white)
Poly mounts
Poly diff mounts
Poly subframe mounts
Reinforced rear subframe mounts
Reinforced trail arm mounts
Custom reinforced rear sway bar (hotchskis style)
Suspension
Front Eibach? mm? with mason endlinks
Rear Ground Control mm? w spherical endlinks
Dinan strut tower
AST 4100 with vorschlag camber plates
Vorschlag 90mm lug adapters
Build in welded 4 point roll bar (black)
Rogue rsm
Reinforced rear shock towers
WTB: E36 ZKW Headlights, ACS Rear Diffuser,E36 M mudflaps front + rear
this is old school m3 build
07' Arctic Silver 911 Turbo
71' Agave Green 2002
10' Gray Landcruiser 200 series
10' White Landcruiser Prado 150 series
Bump for an amazing car, with no expense spared. I've driven and worked on this car personally and it was done right! GLWS Richard
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
e30polak= old school
Did u sell this
I still have it
