Then I'll add the negative mojo. I would never ever take my car to PepBoys. BB is right: get the car outa-there. Even if it works when they are done, I would wonder what problems will show up down the road.... a leak? a loose bolt?
At this point the car is there and parts have been ordered. I agree that Pep Boys is not an ideal choice but I am in Savannah and the choice are limited. We are also not talking about a Bentley. Lol
I asked the mechanic and he said the master cylinder failed and the hydraulic system has been purged of all air.
I’ll keep y’all posted on the outcome.
Please let us know if a new master cyl fixes the problem........
I replaced a soggy flex hose (the one leading to the slave) on my MCoupe last Saturday, trying to make a show on Sunday. I wasn't at home, working out of my Mom's driveway 3 hours away. Got the line swapped with a 3.0 Z3 line with no real trouble (except having to buy an 11mm tubing wrench; I have 3 at home!), then I spent 4 hours trying to bleed the system. I still didn't succeed, working alone. I generally know what I'm doing, but this time got the best of me, for now.
What I'm trying to say is even when you know what your doing, its still a tricky hydralic system to bleed on a Z3. I would not be letting Pep Boys attempt this. I have never met a Pep Boys mechanic that could do much more than an oil change or simple brake pads. By the way, I have never seen a clutch master go bad on a Z3, but I guess is could happen.
-Donny
Just to keep everyone in the loop; they are having problems removing the tube associated with the hydraulic clutch system — they ordered a special tool. Next step is to bleed the system. Should have it complete next three days. I’ll post update.
i thought all you needed to remove the line as long angles needle nose pliers
I'll bet they are "having problems". Removing that "tube" is a pain. I finally got mine out with some PB blaster and a custom-made wrench. Experienced people on this site offer several methods. Maybe you should get the mechanic to read on this site.
Questions:
What happened to the "failed" master-cyl fix?
Why are they removing the "tube"?
Good News. Last week I moved the car from
Pep Boys to a bmw specialist. Master Cylinder inside the car replaced and the problem is fixed.
$700 in labor with me providing the part. Oh well. Luckily pep boys changed the break pads and replaced the slave cylinder at no cost — as the car was there for 3 months — partly because of RONA.
Car runs great now. Lesson is Pep Boys is good at replacing Rims and break pads. But nothing else.
Additionally pep boys ruined the clutch switch and the whole assemble had to be replaced. To be fair $200 for the switch and random parts, fluid and hazardous waste fee.
The $500 was for the labor.
