Results 1 to 7 of 7
Thread: Z3 revs at idle (rpm up and down)
    Jan 2020
    Savannah
    BMW Z3 1.9
    My 1997 Z3 revs when I pull up to a light and sit idle. RPM goes up and then down. I have a K&N cone air filter with the associated sensor.
    What would cause this?
    Thank you
    Jan 2020
    Savannah
    BMW Z3 1.9
    Just a heads up I had a cracked loose rubber tube from the air intake to the engine. I’ll test it tomorrow and see if it fixes the issue.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Check the rubber boot between the air filter and throttle body. If it's the original, good chance there's a hole in it. If you've just installed the K&N* setup there's a good chance the movement put a hole in the boot.
    * DO NOT OVER OIL THE K&N FILTER, it'll kill the MAF.
    Jan 2020
    Savannah
    BMW Z3 1.9
    I replaced the rubber air intake a few months ago. Today I looked and I have a cracked end on the Idle Control Valve Hose. I taped it up and zip tied it for a quick fix before I can order the new hose. I’ll report back if it fixes the problem tomorrow.
    Thank you for the help and the info on oil w/ cone filter.
    Nov 2009
    Herndon, VA
    99 z3 2.8L
    does it only happen when the engine is cold(er)? if so it's likely the Vanos seals need to be replaced. that's currently happening to mine (has been like that for a few years now and i've been quite lazy to fix them).
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Quote Originally Posted by sijray21 View Post
    ... if so it's likely the Vanos seals need to be replaced..
    Not on a 1.9!!
    Nov 2009
    Herndon, VA
    99 z3 2.8L
    oh, true - i forgot to check which version you had. your thought on a vacuum leak somewhere does sound like the right way to go first. any luck with that IACV fix?
  1. Z3 1.9 1998 Revs take a while to come down in traffic
    By brittas in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-12-2020, 10:43 PM
  2. E32 7.50IL Problem EML. Engine problem idle Rpm up/down
    By KORAY in forum 1988 - 1994 (E32)
    Last Post: 06-07-2018, 06:38 PM
  3. 97 e36 2.8 Rough idle at startup then smoth after revs to 2000 rpm ..bad choke?
    By captainronni in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-13-2016, 04:55 PM
  4. 2002 Z3, Rev at 3-3500 RPM
    By BLUEBETTSYE28 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-19-2014, 02:00 PM
  5. Odd rev problem - Engine revving up and down at idle 1100-2100
    By thenerb in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-09-2011, 10:31 AM
