What would issues be if it is a rear main seal blown?
You will leak oil at a high rate and if your car is a manual transmission the oil will ruin the clutch. The cost of the seal is very cheap, the labor to remove and reinstall the transmission is what hurts.
What is actually going on with the car
I believe mine is starting to seep. There's oil between the block and transmission. Not 100% sure it's the rear main. Going to start from top and work down.
