Results 1 to 6 of 6
Thread: N55 Engine from 2014 into a 2011
    Feb 2013
    Waukesha WI
    97M3,325XI, 01 & 03X5
    Hi,
    I am installing a rebuild engine from a 2014 435 -N55 into my 2011 535 xi -N55. I notice the only difference is the head style that accepts different style injectors. The 2014 injector design is different from the 2011. They are secured differently into the heads.
    Q1- once engine is installed. Do I just need to update the injector coding in the DME with the corresponding flow rate calibration number?
    Q2- Am I missing anything here
    Orange County, CA
    E39it, 03 M5, F10 535
    Are the high pressure fuel pump not the same as well? A couple of different electrical connectors also to deal with?
    Sent from my SM-N950U1 using Tapatalk
    E39 M5, E39 SC Touring, F10
    "Beating My Wallet" but loving it!
    Feb 2013
    Waukesha WI
    Quote Originally Posted by jayster0966 View Post
    All parts were switched from the 2011 engine over to the 2014 engine for installation into the 2011 535 xi. Including vacuum and Fuel pump
    Mar 2020
    Chicago, IL
    2011 BMW 535xi, 1991 850
    Hello. I'm looking for a new engine for my 2011 535xi, and was told there are different versions of the N55 engine. What other differences have you noticed between your 2014 and 2011 engines?
    Frank
    May 2005
    Houston, TX.
    15 X5, 02 330i, 09 MiniS
    3 different blocks, 2 different heads. So long as you use everything that goes along with it there is no problem interchanging early and late engines.
    Just an FYI, you must retain the same injectors that were in the car originally. EU5 vs EU6 injectors. The DME is calibrated to run a certain style and won't work with the other (this is more than just the injector number calibration).
  1. 2011 335i X Drive N55 Engine swap
    By Agregware in forum Engine Conversions
    Last Post: 06-08-2016, 11:32 AM
  2. Formula 1 delays introduction of 'green' engines until 2014.
    By gary88 in forum Professional Motorsports sponsored by Bimmerworld
    Last Post: 07-01-2011, 04:22 PM
  3. BMW 4-Cylinder Engines Return to US in 2011 in the Z4 sDrive28i
    By Kevlar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-25-2011, 08:19 PM
  4. BMW Four-Cylinder Engines Return to US in 2011
    Last Post: 02-03-2011, 02:20 AM
  5. Jlevi SW | Juice Box 3 for the N55 Engine
    By Bryan@Jlevi SW in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 09-13-2010, 03:50 PM
