Results 1 to 4 of 4
Thread: Need help... Ac and horn fuse keeps blowing
    Jan 2020
    Lebec ca
    91 E32 and 2018 750i
    Hello everyone...
    I have 91 E32 735IL....Vin#DC27666.... i got couple of problems...
    My Ac and Horn fuse#9 keep blowing some reason any idea? as soon as i turn on the ac the fuse pops
    Also i just recently replaced my steering wheel to Nardi non airbag wheel.. i disconnected the battery before installation after i got done putting it together connected the battery... Now i have no power to my radio ? i did unplug the airbag/SRS plug..
    any help would be appreciated.... Thanks
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    fuse #9 is for horn, IHKA, auxiliary fan, cellular phone (optional extra) http://shark.armchair.mb.ca/~dave/BMW/e32/e32_91.pdf
    I would first check the aux fan, maybe it is blocked by the magnets inside the motor which get lose and then there is too much amps, on my buddies 750 even the wire from aux fan to fuse box had melted. Turn the aux fan by hand if it runs smooth.
    If that is o.k., disconnect the 4 plugs which go into the IHKA control module one after the other, on each side there are 2 plugs, the IHKA control module is behind center console, when you remove the cover on the side of the center console, you have access, only 1 screw each side.
    So with this method you can find out easier the bad part, each pin description, IHKA pinout
    white connector X610 'A'
    1-4 stepper motor fond area
    5 heater sword
    6 aux fan
    7 rear window heater relais
    8 climate control relais
    10 NC
    11 NC
    12+F20 (30)
    13+F20 (30)
    14 - 17 stepper motors for air distribution (recirculation)
    18 light switch LED
    19 light switch LED
    20 TXD
    21 water valve left side
    22 aux water pump relais K8
    23 water valve right side
    24 front window heating relais K8
    25+F20 (30)
    26+F20 (30)
    Blue connector X613 "C"
    Pins are in such way
    13 up to 1
    26 to 14
    1= ground
    2=ground
    3= NC
    4=temp feeler driver side
    5= potentiometer blower motor
    6= temp feeler in engine room
    7=outer temo feeler
    8= potentiometer temperatur driver side
    9=NC
    10+,11+, for stepper motors
    12+F21 (15)
    13+ F21 (15)
    14= ground
    15=ground
    16= potentiometer+ feeler ground
    17= potentiometer flappers
    18 temp feeler left
    19 starter (50)
    20=potentiometer+feed
    21 temp feeler inside
    22 temp feeler reight side
    23+ for stepper motors
    24+for stepper motors
    25+26 = F21 (15)
    26+ F21 (15)
    green X611 „B“
    1 to pin 14,15,16
    2,3,4,5 mixing flap motor left
    6,7,8,9 fresh air stepper motor outside
    10 NC
    11 NC
    12 NC
    13 NC
    14, 15,16 with pin 1 legroom stepper motor left
    17, 18, 19, 20 defrost flap stepper motor
    21, 22, 23 fresh air stepper motor left
    25 NC
    26 NC
    yellow connector 614 „D“
    1,2,3,4 legroom stepper motor right
    5 MPX button
    6 MPX button left
    7 MPX defrost
    8 MPX button right
    9 speed signal
    10 RDX
    11 button rear window defogger/defroster
    12 MPX button recirculation
    13 MPX button aircon
    14, 15, 16, 17 fresh air stepper motor right
    18, 19, 20, 21 mixing flap stepper motor right
    22 NC
    23 NC
    24 NC
    25 NC
    26 NC
    The connectors are:
    13 12 11 10 9 8 7 6 5 4 3 2 1
    26 25 24 23 22 21 20 19 18 17 16 15 14
    See the connectors, they are marked with small numbers outside.
    the SWORD has a 5 pin connector
    Pin 1 connector for the potentiometer for speed regulation at the control panel.
    Pin 2 power supply
    Pin 3: the relay get's contact when the blower fan potentiometer is adjusted, 12 volts come on.
    Pin 4 is ground
    Pin 5 the cable/wire from the blower fan.
    Oct 2007
    Boca Raton, Florida
    89'750iL,98'740iL,00'M5
    I had the same issue, it was the AUX fan that was jammed up and never really turned freely. It can also have an internal short. Good info above if its not the AUX fan.
    BMW 7er Website www.7er.com
    1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
    Jan 2020
    Lebec ca
    Thanks shogan... i will look into it
  1. Need help-headlight fuses keep blowing
    By 3series4ever in forum Lighting sponsored by BAVToys
    Last Post: 06-23-2011, 12:44 AM
  2. HELP MY AC DIED...and FUSE KEEP BLOWING
    By uclabruins1996 in forum 1991 - 1999 (E36)
    Last Post: 09-06-2009, 10:39 PM
  3. Horn fuse keeps blowing
    By hyeteck in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 09-04-2008, 07:48 PM
  4. #37 fuse keeps blowing. Need some help!
    By myblackcar in forum 1991 - 1999 (E36)
    Last Post: 09-26-2007, 02:46 AM
  5. Aux fan fuse keep blowing!!!! need help
    By hongzhi800 in forum 1991 - 1999 (E36)
    Last Post: 08-17-2006, 07:05 AM
