Results 1 to 18 of 18
Thread: torque limit
    Jun 2001
    hell
    turbo e36 m3/ stock s50/e30 m3
    torque limit
    I'm about to have my e30 s50 turbo m3 tuned this coming Friday. Does anyone know the torque limit of the rear axles?
    s50 bored to 86.5mm
    GT35R .82
    MS3Pro
    JE pistons
    Eagle Rods
    2.93 diff
    Tune will be on E85 first and I want to stay under the max torque limit of the axles.
    96 M3, GT4094R, Arrow Rods, CP Pistons, Elring HG, cutring 87mm, 10 mm ARP studs,MS3pro, EMC Intercooler, n54 6 speed with Motiv twin disk, ZT-2 wideband, Zionsville Radiator, X-brace, H&R springs with bilstien shocks, QTP electronic cutout, Line Locks, stock exhaust 455rwtq, 453rwhp at 14 psi 91 octane.......684rwtq, 681rwhp at 24 psi running flex fuel E60 at time of dyno tune.
    Jul 2011
    Bay Area, California
    M3 w/Gt35r
    More importantly, what kind of tires are you running?
    Jun 2001
    hell
    Quote Originally Posted by IR M5 View Post
    for street I will get nt01....for dragging I've used slicks with front runners
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Ive made 1080whp/800wtq factory axles, torque limit of the 188mm axle stub is really around 6-700wtq, if you dont have a 210 thats going to be your weakpoint
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The OP has an E30. Does that change anything? DSS wants $1,800 to make 700 hp axles for the E30 versus $1000 to make 1000 hp axles for the E36, so I am guessing it takes more work to strengthen the E30 axles.
    Apr 2006
    Minnesota eh?
    86 325es
    E30 axles are made of bamboo. Unfortunately the next weak point on them is the outer stub axle where it splines into the hub, so even if you make an indestructible axle shaft it eventually breaks the stub off. The best upgrade for an E30 is to get the entire rear subframe and diff out of a Z3 M coupe or M roadster. They came with a 210 diff, big axles, and bigger axle stubs and hubs. It all bolts right into an E30.
    Jul 2011
    M3 w/Gt35r
    I think my friend with an M52 E30 is on his 3rd set of axles. He’s making around 400wtrq.
    Jun 2001
    hell
    So all e30 axles are the same?... Since this is a e30 m3 i thought they would be stronger than a regular e30..
    What years?
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by m3boost View Post
    What years?
    Klown Kar - 98-02
    Roadster - 98-02
    Jun 2005
    New England
    M52 are smaller at the diff end and might not hold as much. Good stock M3 ones hold power as E36 HatR wrote, but they need rebuilding at 20-25 years old. And the diff stubs snap off the line if running drag radials at somewhere in the 500-600 lb rwtq range. 210 diff is the way to go, and you have to use the bigger M3 spec axles with it since the output stubs are larger.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Ah my fault, i saw e36 in the signature and got excited, i believe you need z3m axles/arms out back to handle the power.
    Toronto, Canada
    E36 Turbo
    E30 188mm axles bend in the wheel hub with aggressive driving around 450-500wtq
    Apr 2006
    Minnesota eh?
    86 325es
    E30, not E36
    What years?
    I don't know if the shafts or CV's are deferent between the M and non M e30 shafts, but the outer axle stub is the same, so they will both have the same eventual weak point.
    Feb 2014
    Galt,CA
    2002 M Coupe
    (snip) The best upgrade for an E30 is to get the entire rear subframe and diff out of a Z3 M coupe or M roadster. They came with a 210 diff, big axles, and bigger axle stubs and hubs. It all bolts right into an E30.
    Sorry, but this is incorrect. My 2002 M Coupe, the last year made, has a 188 diff, just like all of the rest of the M's. I can't speak to the axles and hubs, as I have no point of reference.
    Marty
    Jun 2005
    New England
    Didn’t they have ZF320 5 speeds as well? But if the axles are as strong as E36M3 axles, that helps the OP.
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by MartyBtoo View Post
    Marty
    I thought I remember them being 210’s but I could be wrong. I know for certain the axles are stronger and they use a bigger wheel bearing to accommodate a bigger hub and stub shaft. If the Z3M isn’t a 210 you can get an E28 M5 diff which is a 210 and will fit in the E30/Z3 subframe. I think an E34 M5 diff might fit too. Donovan Marvin or Boris Skoblov would know, they both run this setup in their drag cars.
    Jun 2001
    hell
    Also, the e30 is lighter than the e36, I'm shooting for 600rwhp so the zf320 should be able to handle it. My diff is 2.93
    EGYPT
    E30
    I got 600 whp with 544 lbft torque on my e30 and I was fine ( although I v had alot of wheel spin )
    Actually now I m shooting for 750 whp on stock axles with 3.25 lsd and will see how much would it hold :-)
  1. (Euro 321 ps) Evo 98 - Torque limiter?
    By AMBM in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 03-29-2012, 09:29 PM
  2. Techies. Torque Limiting extensions
    By bmwdirtracer in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-27-2009, 12:23 AM
  3. Torque Limiting Impact Socket -- Worth it?
    By willcg in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 12-14-2008, 01:34 PM
  4. Torque limiting software?
    By Blue528i in forum 1996 - 2003 (E39)
    Last Post: 05-22-2008, 07:34 AM
  5. where can i get some torque limiting sockets?
    By BJO in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-21-2002, 05:25 AM
