I have a Z3 99 2.8.
I have preformed the following maintanace:
Vanos Seals but not entire solenoid
New CAM sensor
Water Pump
Head casket cover
spark plugs
spark plugs cables
engine seals.
New Temp Sensor
New Thermostat sensor
Fuel Pump
Fuel Filter
New Fuel Injectors
New Fuel Lines.
On the winter days I get this rough idle after few normal idle minutes. It then start to idle as if the engine wants to shut off. then after a few mins is runs normal.
What can be my issue guys?
I think your issue may be that you posted in the wrong forum...
